Go to Post Imagine a time before alliances. A time when secrecy was rampid and the Delphi Forum was just in it's baby stage. - Andy Grady [more]
Unread 30-12-2007, 11:25
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Question 3pin RS232 port doesnt work on camera. can't debug while connecting through the DB9.
Hi Everyone,
I have used Kevin's (thanks Kevin!) serial port diagnostic utility to find the problem with our camera. it seems that the 3pin connector on the camera is faulty and thus I can't use the TTL port to connect to the camera.
On the other hand I can't make sure it's all working while connecting the camera to the programming port through the DB9 cable, because the programming port is taken up....
Any Ideas on how I can debug the camera with the terminal while connecting it through the DB9 cable?
Thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 30-12-2007, 11:43
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: 3pin RS232 port doesnt work on camera. can't debug while connecting through the D
Leav,
Have you tried wiring up a 9 pin to PWM-style connector to go through your RS232-TTL adapter? The pinout should be:
Code:
PWM     RS232
1 Blk   5
2 Red   3
3 Wht   2
I'm 95% positive that's correct. If not, you'd have to swap red and white. Also, can you be certain the problem is your 3 pin header and not your RS232-TTL adapter? You could use a similar PWM to 9-pin adapter to connect your computer to the camera's 3-pin connector to check that. You'd need to change the gender of the connectors, but the pinout stays the same.
Unread 30-12-2007, 11:44
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Leav,
It sounds from your message that you are on the right track, but I can't tell for sure.
The most common problem I have seen when there is no communications on that port is because two serial connections are made to the board at the same time. The camera will only support one connection at a time. The other issue I have seen with the 3 pin RS232 port is that the TTL adapter board keeps coming loose from the RC.
That's my $.02.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
No RS232 port alternative Demothesis Programming 7 21-03-2007 18:25
DB9 Port problem Guy_E Programming 4 29-01-2007 17:19
Looking for Borrowed RS232 Camera Port Card from BAE Granite State Event psycho7 Regional Competitions 0 12-03-2006 13:55
Db9 port GOshin Programming 1 02-02-2006 21:39
Camera DB9 / Calibration Port roboticsguy1988 Programming 10 26-01-2005 14:15
