aux analog
whats the aux analog on the joystick?
Re: aux analog
on the KOP white joysticks it is connected to a series of resistors that connect to the thumb switch on the handle. connect one to the OI and read the values from the dashboard.
if i had one in front of me i would look it up myself but there in storage right now |
Re: aux analog
Traditionally, on analog joysticks the AUX channel was tied to a throddle control, for flight simulators. In some other joysticks, its tied to the hat switch, such as the white(current?)KoP joysticks. If you make a custom controller, linear pots still work on this channel, so your really unlimited in what you can do with it.
Re: aux analog
I'm assuming you are using the white joystick from the KOP, so here it goes. It is kind of hard to describe the positioning of them, but if I remember correctly on the top of the joystick there is a button that acts sort of as another joystick, you can push forward, left, etc. A little down and left from that, there are two buttons, above and below eachother. One of these is aux 1, the other is aux2, but I cant remember which is which. To use these buttons, assuming you have the joystick into port 1, would be p1_sw_aux1 (or aux2). That is all I can remember right now, hope it helps.
Re: aux analog
Everyone so far has been describing the WHEEL input. The AUX analog is a pin on the OI's joystick port that isn't connected to anything in either the old black CH Flightsticks or the new white A/B joysticks. You can attach your own 100K variable resistor to it if you want.
| OI LEDs on the 5v Aux | ShadowFireGT | Control System | 7 | 25-02-2007 08:05 |
| Aux 1 & 2 | WGRAY | Programming | 1 | 12-02-2007 14:59 |
| OI Aux Fault light red | Vashts6583 | Control System | 1 | 25-01-2006 23:10 |
| Aux Fuse 3 (Yaw Rate) | Josh Hambright | Electrical | 0 | 18-02-2003 08:22 |
| More than 2 aux switches in 1 port | f22flyboy | Programming | 2 | 01-11-2002 14:44 |
