ultrasonic sensor problems...
i can't figure out how to work the ultrasonic sensor. it works just fine when i use the test program on easyC but i cant get it to work on any of the others. i did everything that the manual said and googled it but it still wont work. can anyone help me?
Can you be a little more specific in your description? it says what it is supposed to and shows the sensor is working when i download the test code(it shows on the terminal window)
Does the sensor work with the test program? yes
What are you trying to do with your program? avoid obstacles
Can you post your program? if i could i wouldn't know how, just joined
Are you using EasyC or another compliler? im using EasyC
Are you using the IFI or Vex controller?what is IFI?
