Go to Post What is this sleep you all speak of...if it wasn't in the KOP than it is not allowed to be used :D - Wayne Doenges [more]
Unread 07-01-2008, 16:19
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: RED "fork truck" robot breaks 6FT Rules in Animation
Originally Posted by 7/16ths Master View Post
well, depends on what u do, the extending piston could reach just up to 6 ft and still knock the trackball off, the area in which the trackball rests is pretty big (around 30 inches i believe). This means that at least some part of the curvature of the ball should be below the 6.5 ft bar and within ur reach. (If it were a square or rectangle, the edge would be at exactly 6 ft) All in all, u can still hit the ball at exactly 6 ft cuz the bottom of the ball i estimate to be at least one or two inches below 6ft. That gives i think some room to play with.
when I ran the field in inventor, the ball is right at or just over the 6 feet, so hitting it from the bottom is not an option, unless you hit it with the other trackball...
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 07-01-2008, 18:58
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
This issue was resolved in Update #1 - I'm closing this one in order to clean up the number of posts no longer needed.
Besides the fact, that the animation isn't an official rules interpretation.
Mike Aubry
Chief Delphi Engineering Lead
Unread 06-01-2008, 00:23
7/16ths Master's Avatar
7/16ths Master 7/16ths Master is offline
AKA: Roberto
FRC #0334 (The Tech Engineers)
Team Role: Mechanical
7/16ths Master is an unknown quantity at this point
Originally Posted by boiler View Post
But according to 6.2.1 the home stretch is bounded by the finish line - if you poke at the ball from underneath, you still haven't crossed the finish line completely, meaning you're still in the home stretch and open to a G36 penalty.
Yea sry if that wasnt very clear, i understand where u are coming from, i should've been a bit more descriptive in what i said
Unread 05-01-2008, 19:33
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
Rookie Year: 2007
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
i think you cant be over 6ft after passing that last line in the red zone...till their finish line. That should be the home stretch like in racing. But after that line you can turn around and bump it off. That way you dont interrupt a last minute hurdle from going over
Unread 05-01-2008, 20:55
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
Team Role: Coach
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
what about reaching over a wall to knock off the opposing teams ball
Curie..
Preview of Dave's "Monster Truck on Mars" David Brinza General Forum 19 22-06-2007 21:55
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
"Red" Whittaker: A Man And His Robots Rohith Surampudi Chit-Chat 1 17-06-2006 14:50
Red Racquetballs for "Half Pipe Hustle" syraweb FIRST Tech Challenge 0 31-01-2006 13:04
YMTC: Bluabot "Descores" Red Tetra Natchez You Make The Call 34 09-04-2005 15:02
