Go to Post How are we as mentors and coaches presenting ourselves? We we are is who they will emulate. It is the nature of coaching, the nature of leading. - MysterE [more]
Unread 05-01-2008, 15:02
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
Re: How does descoring work?
So you could go past the overpass, then turn around and knock the ball off...
Besides, G22 says "by moving", not by turning.
<G22> Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
Unread 05-01-2008, 15:03
AKA: Anthony
I agree w/ the ball hanging idea, any way to calculate how low it hangs?
Unread 05-01-2008, 15:20
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
We measured about 70 inches from the bottom of the ball the floor, at the kickoff.
Unread 05-01-2008, 15:24
AKA: Anthony
Is that measurement, or were you able to calculate that? If it was calculation, I would really like to know how for future reference.
Unread 05-01-2008, 15:40
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Posted this in a couple other threads today.
given a trackball center at (0,0)
given a trackball contact point with a rail at (16,y) (the rails are 32" apart)
given the trackball is 20" and assuming it remains approximately spherical, then...
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
So the contact point for the rails will be 12" below the center of the ball. This means that between the rails, the bottom of the ball should be 8" below them, and thus 2" below the maximum allowed height of a robot in the opponent zone. However, this is in an ideal world where the rails are infinitely thin and the ball is perfectly sperical. Since the rails are 1.5" wide and the ball will deform some, the ball may be slightly higher than where I computed it to be, and the contact space for a robot will be very, very small.
Glad to hear someone did the actual measurement and it was close
Here's a diagram:
http://www.chiefdelphi.com/forums/at...4&d=1199558995
Unread 06-01-2008, 16:36
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
Team Role: Mechanical
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
Here's a diagram:
Umm. Hope not too many people used this number because our team found it to be wrong. We noticed the the equation above used numbers assuming the ball was on center with the pipes. this is not true seeing that the ball rests on the top of the pipes. We found the hang to be (assuming the the 6.5' overpass is on center with the pipes) it would hang only 1.5 inches below the 6' legal limit. If the 6.5' is at the bottom of the pipes it would hang only .67 inches from the 6' limit. this is assuming the the ball in of 40" diameter.
here is the diagram:
http://www.chiefdelphi.com/forums/at...6&d=1199655203
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 05-01-2008, 15:43
AKA: David Bell
We measured that at the kickoff.
But it is possible to figure it out. The overpass bars are 32 inches apart.(the arena 6.2.2) The balls are 40" in diameter.(the game piece 6.3) And the overpass is 78 inches high.
I'll let you do the math.
Unread 05-01-2008, 15:44
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Circular relationship, err, function for a circle. X^2 + Y^2 = R^2
Radius of ball -- 20"
length of overpass -- 32", believedly.
16^2 + y^2 = 20^2
y = 12. 12 is the height from the center of the sphere to the overpass.
20 - 12 = 8" the ball dips down at maximum, giving us only 2" of impact room to play with.
edit: b10. bleh.
I will not leave my account logged on to chiefdelphi again.
How does division work? JBotAlan Programming 14 09-01-2008 10:58
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
