Thread Tools |
Rating:
Display Modes |
Re: 2008 game confusion thread
I did notice that they cleared up any maximum size confusion by changing the max size from 72" x 72" to an 80" diameter.
Code:
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R11>. While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright cylinder). There are no height limits for a ROBOT in its PLAYING CONFIGURATION at any time after the start of the MATCH other than those specified in Rule <G36> about not exceeding the maximum permitted height while in the opponent’s HOME STRETCH. |
Although it clarifys, I really dislike that rule. If you are an arm robot, you probably will make the long deminsion your sides for front/back stability. So, your robot is 38 inches long plus several inches of pool noodle. The balls are 40", so assuming that your gripper is 25" long (in order to get past the center of the ball), your arm can only extend out of the front of your robot ~15". To me, that seems like it unnecessarily stifles some arm designs.
I have a question regarding <G28>
Inadvertandly running into Trackballs in normal play with no intent to herd (control) them. It is basically to prevent one from getting a penalty for herding while in poseession if herding is not the intent, but you hit a trackball.
Still, an official definition would be nice. Add it to the list of things to ask!
Thanks! I can't believe I didn't see that, but it makes a lot of sense now. Of course, once the official Q&A forums are up we'll get FIRST's definition, but this is great for now. Thank you so much.
| 2008 Game Thread | Rick TYler | Rumor Mill | 17 | 30-05-2009 22:58 |
| [Official 2008 Game Design] Game Elements and Subtasks | dlavery | FRC Game Design | 35 | 25-05-2008 22:37 |
| [Official 2008 Game Design] OK, so YOU design the 2008 game... | dlavery | FRC Game Design | 25 | 20-02-2008 23:31 |
| 2008 Game- Overdrive | Chant_358 | General Forum | 155 | 06-01-2008 19:00 |
| 2008 FIRST game | vivek16 | General Forum | 86 | 04-12-2007 09:23 |
