Go to Post But if FIRST followed a "truth in advertising" philosophy for the registration kits, they would contain six cannisters labeled: "Stress", "Anxiety", "Confusion", "Insomnia", "Dietary Inadequacy", "Unbalanced Priorities" And a really big seventh one labeled "Fun" :) - dlavery [more]
Unread 05-01-2008, 16:22
m1k3 m1k3 is offline
FRC #1396
m1k3 is an unknown quantity at this point
Wiring pressure switch
Hey i have been reading around how to wire the pressure switch and i am still confused do you just strip the pwm cable and and connect the black and white wires directly to the 2 prongs of theswitch then connect the the other side to digital input please correct me if im wrong
Unread 05-01-2008, 17:47
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
Re: Wiring pressure switch
You can wire the switch as you said(directly connecting PWM wires to prongs). The way we do it on my team is connect other wires to the switch and put quick-connects on the ends. Then put quick-connects on the end of the PWM cable. This allows you to quickly and easily change the switch or the PWM if one or the other goes bad.
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 05-01-2008, 18:26
FRC #1396
other wires such as
Unread 05-01-2008, 18:40
Team Role: Student
Just any other wires. Just like 1 inch lengths of wire from each post. Not at team's shop right now so I can't get a picture but I'll post one as soon as possible
Unread 05-01-2008, 19:30
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
There are different kinds of pressure switches. I'm not sure what "the pressure switch" may refer to. I didn't see one in my kit. The ones I am familiar with change resistence with the load applied, the lower the resistence, the more pressure. I hook up that kind of sensor in series with a 1/4W resistor and measure the voltage accross the sensor pins with ADC. Using the datasheet information about the resistence output, I can determine the load.
Unread 06-01-2008, 01:04
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Originally Posted by RyanCahoon View Post
Battery-Breaker-Pressure Switch-Compressor
Careful. The pressure switch is not rated to 12 volts, so it must be wired through the robot controller.
2008 Manual <R96> The Nason pressure switch must be connected to the high-pressure side of the pneumatic
circuit (i.e. prior to the pressure regulator) to sense the “stored” pressure of the circuit. The
two wires from the pressure switch must be connected directly to a digital input and ground
terminal on the Robot Controller, and the controller must be programmed to sense the state
of the switch and operate the relay module that powers the compressor.
Last year's manual gives more detail:
2007 Manual <R103> The Nason pressure switch must be connected to the output end of one of the Clippard
tanks to sense the tank’s pressure. The two wires from the pressure switch must be
connected directly to a digital input and ground terminal on the Robot Controller, and the
controller must be programmed to sense the state of the switch and operate the relay
module that powers the compressor. The Parker pressure vent valve must be connected to
a Clippard tank such that, when manually operated, it will vent to the atmosphere to relieve
any stored pressure. The valve must be placed on the ROBOT so that it is visible and
accessible.
Unread 06-01-2008, 13:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Following the Robot section of the rulebook and the Tips and Guidelines, the pressure switch that is supplied in the KOP needs to be wired back to the digital inputs of the RC. The code for control of the compressor using this device (which is required if you are using pneumatics) is part of the default RC code. If you wish to write your own control software, merely copy and paste the lines that relate to compressor control from the default software.
The switch must use only the ground and digital input when using a PWM cable for interconnect. Please remember that one wire of the PWM is connected to the backup battery and must be insulated to prevent damage or failure of the backup battery system.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 06-01-2008, 16:31
FRC #1396
you are talking about the red wire one the pwm cable that you do not need what do you mean connect it to the back up battery? how do you connect it?
Unread 06-01-2008, 16:37
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
Do not connect the red wire; cut it and insulate it. Connect the other two wires to the pressure switch.
Unread 06-01-2008, 16:43
FRC #1396
thanks
Unread 06-01-2008, 23:03
compwiz2008's Avatar
compwiz2008 compwiz2008 is offline
FRC #2139
compwiz2008 is an unknown quantity at this point
What ever you do, don't connect the pressure switch directly to the power of the compressor. We did this last year and it burned it out. What can I say, we were a rookie team.
Unread 07-01-2008, 07:56
Unsung FIRST Hero
Rookie Year: 1996
Robot rulebook prohibits this and it will be checked during inspections. See rule R96 above.
Al
WB9UVJ
www.wildstang.org
Unread 11-01-2008, 12:41
FRC #1396
do you soder the pwmto the prongs
Unread 11-01-2008, 12:44
Unsung FIRST Hero
Rookie Year: 1996
Use a crimp connector on the end of the PWM cable that attaches to the switch. Since the PWM cable is #24 wire or smaller, simply strip back about an inch of the insulation and fold the wire over twice. This will give you an equivalent wire size somewhere between #18 and #22, just the right size for a small crimp.
Never solder to the RC, use the female RC connector supplied with the PWM cable.
Al
WB9UVJ
www.wildstang.org
pressure switch wiring question... Transformers Pneumatics 11 16-02-2008 12:55
Pressure Switch Wiring idahorobot Electrical 1 27-01-2007 11:18
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
Pressure Switch Wiring Question Matthew_H Control System 1 08-02-2004 15:28
