Nocking down other side's ball
In our teams discussion we found a problem in the rules -
<G36> HOME STRETCH Height Restriction – ROBOTS in the HOME STRETCH of the opposing ALLIANCE can not be more than 6 feet tall. A PENALTY will be assigned for each infraction. If you do not get the other side's ball down during the hybrid period - how can you get it down if you can't exceed the 6 foot mark in the opposing stretch? Does that only apply at end game? |
Re: Nocking down other side's ball
pass under the bar and push the ball backward?
grab from behind you? all depends on robot design. ![]() just don't go over 6" in an opponent home zone. |
Re: Knocking down other side's ball
Well if the overpass is AT 6 feet, how can you not exceed the mark and get it down, that's what I'm saying. Regardless of configuration - I don't see a way to knock it down
Pushing the ball backward -- at maximum width, the ball extends 2-3 inches past the bar, at a height of 7.5 feet. Well... good luck.
There's a pretty lively discussion on this very topic going on over here:
http://www.chiefdelphi.com/forums/sh...threadid=60686 |
Ball dips down 8 inches, give or take a bit. You've got two inches of impact room to play with, at the maximum.
the home zone is only from their station wall to the middle of the overpass...so u have to be on the other side...
Besides, you could use another ball to remove a ball. |
Oh I see, so you have to bop it from under or be beyond the limit. We thought that the field was divided 1/2 and 1/2, not 1/4 for each alliance than 1/2 free (1/4 segments)
That clears things up, thanks. |
#10
Another question: does this apply to Hybrid mode as well? Do you have to pass the overpass in HYBRID and push it off BACKWARDS for it to count?
| ball moveing up and than going down agein | keithv708 | Technical Discussion | 11 | 06-01-2008 23:37 |
| pic: Daves other other car :) | Cody Carey | Extra Discussion | 5 | 12-01-2006 05:45 |
| 2X Ball Into the Ball Release | MikeDubreuil | Rules/Strategy | 23 | 28-03-2004 19:31 |
| 13" ball and other parts | Mr. Mac | OCCRA | 0 | 15-10-2003 22:49 |
| Any other Ukrainians here? other then me | Alex Cormier | Chit-Chat | 3 | 25-02-2003 22:02 |
