Go to Post Breath in. Breath out. We still love you - its ok! :^) - KenWittlief [more]
Unread 05-01-2008, 19:21
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Policies on Projectiles?
Is it technically a projectile if, say, the thrown object can be reeled in by string?
Thanks in advance.
Unread 05-01-2008, 19:28
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Policies on Projectiles?
<R05> Exterior or exposed surfaces on the ROBOT shall not present undue hazards to the team
members, event staff or GAME PIECES. Reasonable efforts must be taken to remove,
mitigate, or shield any sharp edges, pinch points, entanglement hazards, projectiles,
extreme visual/audio emitters, etc. from the exterior of the ROBOT. All points and corners
that would be commonly expected to contact a TRACKBALL should have a minimum radiu
of 0.125 inches to avoid becoming a snag/puncture hazard. All edges that would be
commonly expected to contact a TRACKBALL should have a minimum radius of 0.030
inches. All of these potential hazards will be carefully inspected.
This is the only rule with projectiles in it. Once this gets forwarded to the GDC I think they will decide similarly to how they did in 2006 where they summed up that it was unsafe to have parts with springs and stuff flying everywhere. As a safety issue I do not think they will allow it, but please ask on the FIRST Q&As http://forums.usfirst.org/
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 05-01-2008, 22:02
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION
that exceeds the size dimensions specified in Rule <R11>. While in the PLAYING
CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80
inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright
cylinder)
. There are no height limits for a ROBOT in its PLAYING CONFIGURATION at any
time after the start of the MATCH other than those specified in Rule <G36> about not
exceeding the maximum permitted height while in the opponent’s HOME STRETCH.
Can't go very far either....
[wiki]: More restrictive edit policies? Astronouth7303 FIRSTwiki 1 13-12-2005 01:53
Governmental policies in teams Gui Cavalcanti General Forum 14 03-08-2001 23:56
