Go to Post "Everything is possible. Just depends on how much it costs and how much physics you have to apply..." - Kimmeh [more]
Unread 05-01-2008, 21:18
Toby314 Toby314 is offline
FRC #0417 (Stangbots)
Toby314 is an unknown quantity at this point
Robot Size- R11 vs. Inspection Checklist
R11 clearly states the starting size- 28"x38"x60" and 120 lbs. Same as prior years. When I look at the 2008 competition inspection checklist, it lists "Robot Class"- (1=4' + 120lbs, 2= 5' + 110lbs, 3+6" = 100lbs). Item #1 on the checklist refers to "class height".
I don't see any reference to "robot class" or "class height" anywhere in the manual. Did I miss something??? All of the rules referenced for item #1 don't indicate a range of heights and weights.
Unread 05-01-2008, 21:21
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: Robot Size- R11 vs. Inspection Checklist
perhaps reusing last years was a mistake lol
Unread 05-01-2008, 21:23
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Most likely a mistake, I'd stick to the Rules in Secion 8 for now.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 05-01-2008, 21:27
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
Team Role: Leadership
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
I guess housekeeping missed a few spots.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 07-01-2008, 10:09
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I guess you could say that housekeeping did indeed miss a spot. The concept of various weight/size classes was present in earlier pre-kickoff revs of the 2008 Robot Rules but was removed relatively recently. I didn't notice the error until this thread.
Thanks for pointing this out! I'll get this into an update ASAP.
For future reference, PLEASE consider the latest version of Section 8 to be the governing document in addition to GDC rulings on the forums. I'll do my best to ensure that the inspection documents accurately reflect the latest and greatest.
Russ Beavis
Chief Inspector
Robot Inspection Checklist ChuckDickerson Technical Discussion 2 16-02-2006 21:30
Update 11 is posted, with Inspection Checklist Tristan Lall General Forum 2 15-02-2005 21:34
Inspection Checklist Draft Available Yan Wang General Forum 1 26-02-2004 20:14
Have you seen the Inspection Checklist? Matthew_H General Forum 20 23-02-2003 19:55
Robot Inspection Yan Wang Regional Competitions 1 20-02-2003 21:00
