Go to Post This, right here, is why I participate in FRC. Changing lives, one corndog at a time. - Jared Russell [more]
Unread 06-01-2008, 08:07
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: How do you get your other ball
Unfortunately, the wedge rule is back and very clear in <R19>: "Neither offensive nor defensive wedges are allowed"
Hi!
Unread 06-01-2008, 23:27
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
A part of the rule directly after that sentence reads: All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical...
So, since 2005, our robots have always had a 9 1/2 degree wedge, which is perfectly legal.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 06-01-2008, 23:43
Wvoo369 Wvoo369 is offline
FRC #0935 (Railer Robotics)
Team Role: Animator
Wvoo369 is an unknown quantity at this point
There is another strategy a team can you to knock off the trackball on the opposing side. In the Hybrid mode you only receive a penalty of two points when going above the 6' zone. This would allow you to use that trackball in the telioperated period rather then having to knock it down in the telioperated period and potentially losing 10 points or more.
If I have misread the rules please clarify for me. Thank you.
Unread 07-01-2008, 00:00
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I see only one point value for penalties (unless you count disable and DQ as point values.) It isn't 2 points. There is no distinction made between Hybrid and Teleoperated.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 06-01-2008, 08:14
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
The arena is divided into four distinct areas, movement between areas is counterclockwise (G42). Once you are in an area, you should be able to move in any direction you want, just leave a passing lane. You could go back and knock the trackball down from the other side since you can not be over six feet tall while in opposing alliances home stretch (G36).
Boiler nailed it, if the trackball stays up for the entire match, it becomes 12 points.
I would like to see a definition of "in" regarding rule G36. Do the boundaries of the home stretch extend to the ceiling? Meaning that if any part of your robot passes over the home stretch without touching the floor, would it be considered a violation? G22 talks about breaking the plane being a violation, rule G36 does not.
Unread 06-01-2008, 15:24
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
you could get the ball while not beeing in the opposing side's home strech zone.
You cross their finish line, go back dropping the ball/grabbing it and there you have it.
This might be intentional by the GDC, not a mistake like many of us hurried to asume.
The mistake though, is in the Game Animation, which means that Lavery is still messing with our heads!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 06-01-2008, 16:19
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Chuck proposed that. You can't recross any lines or even break the planes unless you have gone a full lap. So, you cross the finish line and then hit the ball. You now run the risk of getting a 10-pointer for breaking the plane.
Past teams:
Unread 06-01-2008, 16:20
Tottanka's Avatar
AKA: Liron Gurvitz
But it might jube be woeth it in order to get the ball dropped and usable for Hurdling.
Unread 06-01-2008, 16:28
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Why do you risk getting the penalty?
The finish line is directly under the 2nd bar. As long as whatever you hit the trackball with is vertical and is outside the bar, then you have not broken the plane. The ball will overhang the bar and thus can be hit and knocked off the rails without penalty.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 06-01-2008, 16:31
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
If you are slightly off/your vertical member bends over the line, you broke the plane. If a ref sees you, they can give a penalty. I'm also not sure it's physically possible to do this. (ball and rail dynamics)
Past teams:
Unread 06-01-2008, 16:40
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I'm not too concerned about the vertical member being off (this is what spirit levels are for ) ... I'd be more concerned with a portion of the robot hanging over the finish line while we extend above the 6' high restriction.
___________________
- Tennyson, Ulysses
Unread 06-01-2008, 16:46
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
Team Role: Mechanical
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
given a trackball center at (0,0)
given a trackball contact point with a rail at (16,y) (the rails are 32" apart)
given the trackball is 20" and assuming it remains approximately spherical, then...
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
So the contact point for the rails will be 12" below the center of the ball. This means that between the rails, the bottom of the ball should be 8" below them, and thus 2" below the maximum allowed height of a robot in the opponent zone. However, this is in an ideal world where the rails are infinitely thin and the ball is perfectly sperical. Since the rails are 1.5" wide and the ball will deform some, the ball may be slightly higher than where I computed it to be, and the contact space for a robot will be very, very small.
I know this math has been posted in a few other threads but the math is faulty so ill post my teams
We noticed the the equation above used numbers assuming the ball was on center with the pipes. this is not true seeing that the ball rests on the top of the pipes. We found the hang to be (assuming the the 6.5' overpass is on center with the pipes) it would hang only 1.5 inches below the 6' legal limit. If the 6.5' is at the bottom of the pipes it would hang only .67 inches from the 6' limit. this is assuming the the ball in of 40" diameter.
here is the diagram:
http://www.chiefdelphi.com/forums/at...6&d=1199655203
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 06-01-2008, 17:08
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Suppose you clear the finish line then raise something to contact the part of the ball that overhangs the overpass. If this appendage of the robot contacts the pipe supporting the ball, have you broken the plane? Would this be a violation of <G22> even if the robot base is not moving in a clockwise direction? Lot's of stuff for FIRST Q&A to address on this topic...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 06-01-2008, 19:00
GBIT's Avatar
AKA: Jared
no the Home stretch is ,from what my team told me, the wall to the preceding edge of the black and white checker.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
  #15   Spotlight this post!
Unread 06-01-2008, 19:12
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
It doesn't matter what anyone tells you if the Game Design Committee says differently. The GDC hasn't declared which edge is the right one, or if it's the middle, or anything. Unless they can show you in the manual which edge is right, it's a question for Q&A.
NOTE: On the same topic, CD answers are NOT official rulings. We can offer our interpretations of the rules, we can point you to the appropriate rule, and we can send you to the Q&A for the answer. More than that we cannot do.
Past teams:
How early in the season did you get to test your programming? EHaskins Programming 18 20-02-2007 00:22
How did you GET your job(s)? JVN Career 45 18-02-2006 15:07
How Did You Get Your Sponsor? Summmergrl2298 Chit-Chat 7 30-01-2002 23:40
How to get your picture under your username: Brandon Martus CD Forum Support 0 07-01-2002 09:23
