Interesting IR sensor test results
My team just got our board today (we were on break and unable to get into the school to retrieve it). I decided to take it home, get it working, and preform some unofficial tests. I searched before posting this and didn't find anything similar, sorry if someone has already posted this.
I found that the board will reliably receive and indicate signals from much over 30 feet in the presence of a lot of ambient light. I took two mag-lights and pointed them straight at the IR sensor on the board and the board still reliably received and indicated signals from the TV remote I was using. (30 feet was actually 30 paces, and I only stopped there because I ran out of room) I also found that the board could receive signals from 360 degrees. With my hand covering the LEDs on the remote the board reliably received and indicated commands from 2 feet away. Now, the really interesting thing I discovered is that it takes only 1 other signal to jam the board. I made sure the board could reliably receive and indicate the signal from 2 feet away, then pressed a button on another remote while also pressing a button on the remote the board was trained with. With all of the remotes I tested (5), it took only one of them at any one time to completely jam the receiver. I suspect things will get interesting with 6 teams all sending signals to their robots at once. I guess you probably shouldn't program your robot to drive very fast during autonomous or else you might end up slamming into a wall before you can get your bot to acknowledge your turn command. I hope no one will abuse this and just jam the entire field for everyone with their remote. Last edited by Mr. Freeman : 05-01-2008 at 22:26. |
Re: Interesting IR sensor test results
While you're in the testing mood, would you try a fluorescent light on the IR sensor and see how much that might interfere? I suspect it might be worse and would probably better simulate the metal-halide lamps that some of the gyms and arenas are lit with.
fluorescent light testing i think is kind of pointless, fluorescent shine primarly in the ultra-violet frequencies (but have coating so they radiate in normal light) therefore i think their disruption would be minimum.
I was helping Mr Freeman do the experiment and all the houselights are compact fluorescents which we turned on for the test. So, we already tried it. We are still pretty surprised that it still sees the signals when fired through your hand. Very very sensitive little receiver (enough though we know that some IR penetrates the body).
I personally would not put any reliance on the IR system at all. Unless many optics and precise targeting are used, it will be impossible to send a clean signal with 5 others being broadcasted. Plus, let's not forget about the IR lap detectors...
gyms and arenas can be lite with (depending on age) very harsh lights;
that are not fluorescent, if these have are made like standard bulbs, with filliment (excuse spelling) then they would throw alot of infared or carbon arc lamps (these were phased out) but some places still use them, these are lite with a arc of electrons jumping between the carbon poles, this would be an infared nightmare (radates all the way across the spectrum from radio to light, but mainly concetrated in the infared to light wave lenght i think). best test i think would be take a million candle power flash light, and 5 other remotes and have them all send interference, if you can get a single throught that then your cooking with gas! Last edited by XXShadowXX : 05-01-2008 at 23:31. |
That's what we suspected. Well, There is always a custom fequency ultrasonic reciever and transmitter.
When the remotes were jamming each other did the frequencies of the remote matter or did any frequency jam any other frequency?
I believe tht FIRST wants us to find a solution for the Jamming. It was highly encoureaged to make a tube that will get signals only from a certain location during the kick off, including Dave's cercastic remarks on that. It is n idea i personnaly support (its a challange for us!). Any i am also sure that some neat solutions will be found.
A sugestion: Plan on usng the IR only when really cose to the Robocoaches, and have a pipe from the Ir direct to them. There's a lot of planning here and a lot of sensors usage. |
#10
So I guess any frequency will jam any other frequency. |
#11
Are you sure that flesh is transparent to IR light? I'd think a more probable explanation is that it reflected off your hand to surrounding walls, and then got picked up by the sensor. You could test this with an IR night-vision video camera and see if the room gets lit up when you fire the tv remote. |
#12
Most IR remotes use one of three frequencies; 36, 38, and 40 KHz. But their light outputs are all the same IR; the sensor will see them all.
IR remotes and their receivers use different codes, not different frequencies. If you're sending one code while someone else is sending another, the chances of either one getting through without errors is very small. Try this at home: Hold the button on one remote (VCR?) and then try to use another (TV?). Very seldom will it work. There will be up to six robocoaches operating signaling devices during the Hybrid period. |
#13
I know for one of my college classes we had to make an IR receiver transmitter for a robot we were using and we could control the frequency at which we broadcasted the signal and would just make a good enough filter so that the phototransistors would only see close to this frequency. If you are allowed to do something like this you would get no interference from anyone else (as long as there not on the same frequency but you can ask them and can change your's accordingly if your setup allows it)
I haven't read the specifics of what your allowed to use but this consists of a simple IR LED's and some phototransistors which I don't think are against the rules. I am also not on a team anymore so I haven't seen the receiver board or any spec sheets for it. |
| pic: Robostang's Analog Sensor test software | Robostang 548 | Extra Discussion | 11 | 23-12-2007 09:55 |
| Battery Life, 50A load discharge test method/results | Dale(294engr] | Electrical | 5 | 22-01-2006 09:14 |
| AP test results | RudimentaryPeni | Chit-Chat | 29 | 19-07-2004 18:06 |
| How do we Test our Beacon and Sensor | Matthew_H | Technical Discussion | 7 | 07-02-2004 15:42 |
| Results of traction test | IBApril180 | Technical Discussion | 3 | 04-01-2003 18:56 |
