Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Unread 05-01-2008, 23:39
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Rookie Year: 2007
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Match Ranking Points
I was looking through the tournament manual and saw this:
Originally Posted by 9.3.5 Match Ranking Points
All teams on the winning ALLIANCE will receive a number of ranking points equal to the un-penalized score (the score without any assessed penalties) of the losing ALLIANCE. All teams on the losing ALLIANCE will receive a number of ranking points equal to their final score (with any assessed penalties). In the case of a tie, all participating teams will receive a number of ranking points equal to their ALLIANCE score (with any assessed penalties).
Originally Posted by 9.3.8 Ranking Score
The total number of ranking points earned by a team throughout their qualification matches, divided by the number of matches played (excluding any SURROGATE matches), then truncated to two decimal places, will be their ranking score.
Note: because your ranking score is derived directly from the match scores of your opponent ALLIANCES, it is in your interest that both your ALLIANCE and the ALLIANCES you “defeat” obtain a high score. The most valuable “WIN” results from a close, high-score match.
Originally Posted by 9.3.10 Qualification Seeding
All teams in attendance will be seeded during the qualification matches. If the number of teams in attendance is 'n', they will be seeded '1' through 'n', with '1' being the highest seeded team and 'n' being the lowest seeded team.
The scoring system will use the following seeding method:
  • Teams will be broken into tiers based on their qualifying score. A tier is made up of all teams with the same qualifying score. Tiers will be seeded in decreasing order by qualifying score.
  • Within each tier, teams will be seeded in decreasing order by their ranking score.
  • If any teams within a tier have the same ranking score, they will then be seeded in decreasing order by their highest match score.
  • If any teams within a tier have the same ranking score and the same highest match score, then the scoring system will seed those teams based on a random electronic coin toss.
Anyone trying to think of a way of defending (granted, I don't see how one could in this game) might want to pay attention to these rules. Of course, just winning a match is still far more important, but still something to think about.
It might even be in your favor to help your opposing alliance if you are winning by a landslide. Maybe knock down the opposing trackball if you are matched against an alliance of all rookie bots (hey, rookies could still do great! we were once rookies... ok, so we didn't end up having a working arm...) or robots with broken manipulators / trackball knocking devices. We could see some interesting gameplay this year.
(I can dream of this coming into play for us, can't I? )
Unread 06-01-2008, 00:14
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
Rookie Year: 2007
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
Re: Match Ranking Points
if there are no penalties then both teams get the same ranking points
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 06-01-2008, 00:24
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
yes, but RPs are much less important than the W/L record.
Hi!
Unread 06-01-2008, 00:25
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
This is like when in AimHigh you could shoot into your opponents goal if you had already won and just wanted higher rankings. There are always ways to get these points but the reality is at most regionals they will not matter. Only for one or two but I remember at Bayou there was a clear cut seed 1 and at LSR there was maybe a tie for top two if even that so in most places it won't even be an issue. ....
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Does 9.3.5 Match Ranking make sense? soap108 Rules/Strategy 4 12-02-2007 16:28
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
pic: QF match that set new record score = 220 points CD47-Bot Extra Discussion 3 29-03-2004 15:34
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 25-03-2004 01:53
Pre-Match/Post- Match Pit Routine Mark_lyons General Forum 14 31-03-2002 15:19
