Go to Post The shirts. The buttons. The capes. That feeling you get when you first glimpse the arena and all the empty pits, and the only thing is promise. When the last bit of confetti has fallen, and nobody leaves the field. We are fortunate. - Taylor [more]
Unread 09-01-2008, 16:29
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Differential?
Originally Posted by caraddicted101 View Post
I saw a team use a differential a few years back. They steered the robot using a rack and pinion design. Since you are asking this question for a game like this it makes me want to wonder, Drifting!? It would be a hard task to accomplish seeing as the floor is carpet, but it's a thought.
Drifting sounds like a good way to completely destroy FIRST's carpets...
We've used a software differential for the last few years. Usually with encoders. Though last season we got one working using only a gyro.
Works well enough in either case. You don't even need to do the proper trig - all you want to do is reduce the slip on the inside wheel to an acceptable level.
Unread 09-01-2008, 21:32
King Duke's Avatar
King Duke King Duke is offline
FRC #0991 (Dukes)
Team Role: Leadership
King Duke is a jewel in the roughKing Duke is a jewel in the roughKing Duke is a jewel in the rough
Send a message via AIM to King Duke
Re: Differential?
by reducing the slip you decrease the RPM's of the inner wheel?
Mr. Ames
#991 The DUKES!!!!! from Phoenix, Arizona
Cornell MineSweeper- Business is Booming.
Unread 09-01-2008, 23:39
Darunada Darunada is offline
AKA: Lea Fairbanks
FRC #4598
Darunada is on a distinguished road
Re: Differential?
We have decided against a differential in hardware, and probably in software as well. I hope this thread can help others though!
Thanks!
Unread 10-01-2008, 01:17
Nick02's Avatar
Nick02 Nick02 is offline
AKA: nick
FRC #0991 (Dukes)
Team Role: Mechanical
Nick02 is an unknown quantity at this point
Re: Differential?
I have personally dealt with open diff's and locking diff's in my vehicle. My truck had the stock rearend with the open gears in it, it behaved by doing great in traffic but off-road it sucked if you got one rear wheel in dirt/gravel/air that wheel would spin and the vehicle would go backwards (I forgot to mention I have a 2wd). So I bought a powertrack locking diff and it kicks butt because it "ratchets" around corners using plates to unlock the rear wheels together however it is temperamental and you can’t WOT around a corner or else it will lock up. I can go into a corner and floor it (WOT) the locking diff will lock causing the wheels to chirp and the truck's turning is greatly decreased. When it receives alot of torque from the motor and one wheel slips it will engage and lock the two rear wheels together this makes it great offroad and when doing burnouts (no more pegged leg burnouts ;P).
I doubt that there would be a situation in this years game where you’re robot would have ½ of the drive wheels on one side of the roboto off the ground and thus, an open diff would be a good mechanical means of keeping the wheels nice and smooth through turns.
And here’s a great article on how open diff’s work
http://auto.howstuffworks.com/differential2.htm
I like the idea of programming a “diff” though.
Nick mechanical/electrical
El Presidente of brophy robotics
Unread 10-01-2008, 13:06
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
FRC #0461 (Westside Boiler Invasion)
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
Re: Differential?
if you want to build a diff, look at a lego diff, it's just a dumbed down version. i would however add in a fourth gear to make it work more like a real diff
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
Unread 08-01-2008, 16:37
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Differential?
QC Elite last year used a software/electronic differential for our coordinatated steering system. We found the two arcs that would pass through the wheels on each side, and then used a ratio between the two sides to figure out the different speeds the wheels needed to turn. Worked real well.
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 08-01-2008, 21:50
NHPilot NHPilot is offline
NHPilot is an unknown quantity at this point
Wink Re: Differential?
((If you were to build a drivetrain that utilizes an "Open Differential", and if you were to lift one of the wheels off of the carpet, the wheel off of the carpet would receive all of the torque and it would spin. The other wheel (on the carpet) would receive no torque and would not move.))
I agree completely but suggest that both outputs from the differential transmit 'equal' torque. By that I mean that both wheels get the same amount of torque, but, because the wheel in the air only requires say .2 ft/lbs to turn it due to lack of resistance, that same .2 ft/lbs of torque at the other wheel is not enough to cause that wheel to rotate. So when the free spinning wheel gets brakes applied, the amount of torque required to turn it increases (at both wheels) until the wheel with good traction is easier to rotate than the now stopped wheel, and the vehicle moves.
Same effect but just a different explanation.
VEX Differential RoboticEngineer Programming 8 23-02-2006 00:40
Methods of Solving Differential Equations sanddrag Math and Science 7 26-01-2006 14:38
Where Can I get A Differential redbeard0531 Technical Discussion 1 07-01-2003 00:42
4x4 software differential archiver 2000 13 24-06-2002 00:21
