Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 06-01-2008, 16:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Omni wheels?
Originally Posted by tawnos23 View Post
I would suggest to buy metal omniwheels instead of the plastic ones. Our first year with omniwheels we bought the plastic ones, and they broke to pieces during the course of a regional.
We have used AM plastic wheel for the last two years. In 4 regionals, 2 IRI's, 1 championship, and hundreds of hours of demonstrations we have never had a single failure.
Unread 06-01-2008, 17:51
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Team Role: Leadership
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Re: Omni wheels?
Although mecanum wheel provide excellent mobility and a relatively fast movement speed, the system to make them work weighs too much. Each wheel weighs about 2.5 pounds + 2.5" CIM Motor + transmission = alot of weight simply to make the robot move
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Unread 06-01-2008, 18:06
kristenliz_28's Avatar
kristenliz_28 kristenliz_28 is offline
Team girl squad *cape whoosh*
AKA: Kristen
FRC #0020 (Team 20- the rocketeers)
Team Role: Mechanical
Rookie Year: 2007
kristenliz_28 has a spectacular aura aboutkristenliz_28 has a spectacular aura about
Re: Omni wheels?
our team was considering using omni wheels, but it would be hard to herd/move the balls out of the way. Of course, I guess the reason to use omni wheels is so you can juts go around quickly
Unread 06-01-2008, 19:07
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Re: Omni wheels?
Yes, that first year, I thought that it was a good idea to put a 10% fiberglass fill into the black polycarbonate. While that made the tensile strength higher, it was lower rated on the Izod impact rating. The fiberglass mad the material brittle, and when teams hit the side of the 1 point ramp in 2006, the wheels broke. The result of these breaks were improving these wheels and creating the aluminum omni wheels.
So... last year we had black polycarbonate with no fiberglass filler, and that resulted in zero complaints about breakages.
If I had to pick which omni wheel to use on a FRC robot, I would choose the 6" aluminum omni wheel, and use an Omni Spacer to make them a dualie omni wheel. That is a sweet setup. The polycarbonate wheels are nice, and can handle 2 bearings, but the aluminum wheels take up less space (they are thinner) and they are repairable. The only negative about the aluminum omni wheels is that they only have the ability to have 1 bearing mounted to them, that is unless you add on an extra hub.
Andy B.
Unread 06-01-2008, 20:05
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Omni wheels?
Last year we used the plastic polycarbonate omni wheels and we are a very happy customer. Zero problems. In fact we are ordering more for this year tomorrow.
Ed Barker
Unread 08-01-2008, 20:23
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: Omni wheels?
I agree dual 6" aluminum omniwheels are sweet. In '06 my team spent a lot of effort building our own, so it was nice to have the option of buying them from AndyMark last year.
Our '07 chassis used single 6" aluminum AM omniwheels on the corners of a 6WD kitbot, and kit AM wheels in the middle with one CIM per side -- not a defense-oriented drivetrain, but nice for maneuvering. To get around the single bearing limitation Andy mentioned above, we mounted the inboard bearings in the sprockets that drove each omniwheel. This required boring out the center hole in the sprocket to 1.125", which is a relatively easy lathe operation in a standard 3-jaw chuck if the tooth count is a multiple of three.
Richard Wallace
since 2003
Unread 07-01-2008, 13:59
Zoysiamo's Avatar
Zoysiamo Zoysiamo is offline
In the champeenship?
AKA: Jeff Atkinson
FRC #2614 (MARS)
Zoysiamo is an unknown quantity at this point
Post Re: Omni wheels?
In 2006 I helped create an omni drivetrain for team 859 using the poly AndyMark omniwheels, only to have the roller mounts (around the circumference of the wheel) shatter several times on the ramp. Other teams had better luck with small caster-style wheels such as from omniwheels.com or mechanum (angled roller) wheels.
At least without ramps this year's game should be easier on omniwheels.
Unread 07-01-2008, 15:14
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Omni wheels?
We used the AM plastic omniwheels last year with absolutely no problems.
We will have to replace the rollers because in the course of 2 regionals and the championships, we wore them down...
this year we are going to a new idea.. using two of the poly wheels staggered to produce a wider wheel.
Please take a look a the attached jpg ... we are direct driving the omniwheels with Dewalt transmissions...
This is a holonomic robot....
Name:	dually polycarbonate small.jpg
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 07-01-2008, 18:20
Re: Omni wheels?
what are the benefits of direct driving the omni wheels instead of using two normal wheels and two omni in the front?
Armando Gonzalez
San Juan, PR
Awards
Unread 07-01-2008, 18:31
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Omni wheels?
In my years of robotics i havent found an advantage to driving omniwheels other that more power.
Unread 08-01-2008, 16:54
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Omni wheels?
That is going to be one really fast robot!
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 08-01-2008, 19:59
sweetie_pi sweetie_pi is offline
AKA: Nica
FRC #2189
Rookie Year: 2007
sweetie_pi is an unknown quantity at this point
Re: Help with Omni wheels?
i have never used omni wheels but my team is thinking about it. What is the difference between metal and plastic wheels on the carpet? Does one work better than another?
Unread 08-01-2008, 20:08
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Quick answer: metal wheels are not allowed. All the omni wheels in this competition have plastic rollers. So the main difference would be weight, I think.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-01-2008, 23:43
Darunada Darunada is offline
AKA: Lea Fairbanks
FRC #4598
Darunada is on a distinguished road
Re: Omni wheels?
WE shattered a junky plastic one all over the field tw years back... and another one demonstrating post-season. The ones currently on the robot aren't very "omni" as most of the small wheels are locked in place by what I assume is a crushing force of the omniwheel plastic colapsing.
That said, last year we used these: http://andymark.biz/am-0097.html
with excellent results, and we will use them again in the future...
  #15   Spotlight this post!
Unread 09-01-2008, 23:55
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I wouldn't say mecanum wheels are better than omni wheels, they are quite different and transfer power differently to the movement of the bot, but I wouldn't call them better, I find the biggest thing about having a strafing bot, is to make sure your driving practices, and uses all the advantages the wheels give you (too often do I see a bot with mecanums or omnis being driving like a 4wd bot, I dislike it lol)
for the record omni and mecanums have slightly different pros and cons about them and depending on how you want to drive it or how skilled your driver is at controlling them, ethier one could seem "better" than the other for your team, I personally perfer omns over mecanums!
Help with Omni-wheels The GarbageMan Kit & Additional Hardware 12 10-04-2007 12:39
can bots with omni wheels capable of going up robots? Tri_Lam Technical Discussion 12 13-01-2007 16:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Motors with Omni-Wheels jlewellen Motors 5 11-01-2006 23:24
Omni Wheels edomus General Forum 6 06-02-2004 13:35
