Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
  #31   Spotlight this post!
Unread 23-01-2008, 08:46
Kit Gerhart's Avatar
Kit Gerhart Kit Gerhart is offline
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Rookie Year: 1996
Kit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond repute
Send a message via AIM to Kit Gerhart
Re: 2008 Motor Specs
Originally Posted by reflion View Post
Anybody know the torque of the Taigene motor? It's not listed on the specs FIRST provided, and we need to know if its a motor that we can use for our task.
I haven't found actual specs on the the Taigene motor, but we have determined that it is REALLY WIMPY compared to a similar-looking one we have, probably from 2005. Our very scientific tests involved connecting the two motors to a battery in both directions and observing how much the motors "jump" from torque reaction. The old one jumps a lot more. Our second test was of the "don't try this at home" variety. A person held the motor in one hand and an adjustable wrench on the output shaft in the other hand while a second person connected the motor wires to a battery. The old motor had a lot more torque. The motors have different worm and ring gear designs, and they also have different "winds."
Team 45, TechnoKats, 1996-2002
Team 1062, The Storm, 2003
Team 233, "The Pink Team," 2004-present
The views I express here are mine, and mine alone, not those of my team, FIRST, or my previous teams.
  #32   Spotlight this post!
Unread 24-01-2008, 21:10
Ken Stafford Ken Stafford is offline
AKA: Blackhole
FRC #0190 (Gompei and the HERD)
Rookie Year: 1998
Ken Stafford is a glorious beacon of lightKen Stafford is a glorious beacon of lightKen Stafford is a glorious beacon of lightKen Stafford is a glorious beacon of lightKen Stafford is a glorious beacon of lightKen Stafford is a glorious beacon of light
2008 Motor Specs (Taigene Van Door)
Originally Posted by Arefin Bari View Post
Download JVN's 2008 Design Calculator. All motor specs are on there under the specs tab.
John points out that the specs have either been experimentally determined, or taken from the manufacturer.
I have yet to find specs of all these motors on the FIRST site.
Beware, at least some of the data on John's calculator are NOT for 2008! We just ran bench tests on the new Taigene Van Door motor (see attached), we will have the complete data for this motor and others available on the first.wpi.edu site very soon. The condensed data for the new Van Door is as follows (all corrected to 12.0V input): Free running--48 rpm/1.2 Amps, Stall--360 in-lbs/24.2 Amps. Max power: 53W. So it is about 20% less powerful than the last Van Door we were supplied.
  #33   Spotlight this post!
Unread 28-01-2008, 01:02
minirose224 minirose224 is offline
AKA: Danny Rose
FRC #1816 (Green Machine)
Team Role: Mechanical
minirose224 is an unknown quantity at this point
I see these specs posted by teams about the Taigene Van Door Motor the what FIRST has posted on its website. My question is will FIRST ever post official performance specs about the Taigene Motor?
  #34   Spotlight this post!
Unread 28-01-2008, 01:16
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
I wouldn't consider the "Jump" as an accurate method of torque testing
  #35   Spotlight this post!
Unread 28-01-2008, 08:03
Rookie Year: 1996
The "jump" should be a good indicator if the mass of the armatures of both motors is the same, but I don't know for sure that it is. The "wrench on the shaft" test is a sure indicator of a difference, though.
  #36   Spotlight this post!
Unread 29-01-2008, 00:54
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Where can I find information regarding the gear pitch and such dimensions etc, for this years FP motor? I think I missed something this year...
Thanks,
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
  #37   Spotlight this post!
Unread 29-01-2008, 09:28
Rookie Year: 1996
Thanks,
-Bharat
The pinion on the motor should be 32 pitch. I think this year's is 19 tooth, but you can verify that by counting the teeth.
  #38   Spotlight this post!
Unread 04-02-2008, 20:57
Maximus-Prime Maximus-Prime is offline
FRC #1168 (Malvern Robotics)
Maximus-Prime is an unknown quantity at this point
Ok, I'm really confused and really tired. My team needs to use the 16627960 Motor and the 16631023 Motor TOGETHER. Meaning we need to know if they run with the same specs I guess. Would it work having them oh lets say on opposite sides of the same shaft running to flip it up? For us if they don't run exactly the same it will destroy itself (trust me we know.) Anyway, I've been working to try to figure this out for several hours, any help would be really appriciated. I looked at Keyangs website AND FIRSTs official specs, Keyang isn't any help and FIRSTs specs are too small (and side ways on my screen) to read.
  #39   Spotlight this post!
Unread 04-02-2008, 22:24
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
The specs on the FIRST website are the same; points on the corners are 22-41 RPM @ 6 Nm, 45-64 RPM @ 1.8 Nm.
Close enough to taste it, too far to reach it
  #40   Spotlight this post!
Unread 06-02-2008, 08:57
braiano braiano is offline
FRC #0157
braiano is an unknown quantity at this point
can anyone please give me the specs for the keyang motor im having difficulty finding them and cant read them on the usfirst site
thanks
  #41   Spotlight this post!
Unread 12-02-2008, 04:36
Frank Neuperger Frank Neuperger is offline
FRC #0842
Rookie Year: 2007
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
JVN spec for denso motor does not seem right.
JVN listed Stall torque for Nippon Denso motor of 9.2 N-m works out to 6.78 ft lbs.
In testing today, we measured ~12 lbs force on ~ 2 foot weightless arm today using a decent load cell. This is closer to 24 ft lbs so this is different from JVN spec by a factor of almost 4.
Does anyone have any test results on the Denso motor.
Robot Specs 2008 N0s3Nugg3t General Forum 7 06-01-2008 09:18
Motor Specs??? tenfour General Forum 1 10-01-2003 17:56
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
