Go to Post 1114. You can never count out those sneaky Canadians. - jblay [more]
Unread 06-01-2008, 10:26
simrat.s simrat.s is offline
FRC #1241 (Theory6)
Team Role: Electrical
Rookie Year: 2007
simrat.s is an unknown quantity at this point
IR Sensors
How many IR sensors can are you allowed to have on the 2008 Robot?
In the rules (<R65>) it states:
"communicate no more than four messages, states or conditions to the ROBOT (please refer to Rule <R69> and Rule <G01> for additional information) during any single MATCH."
Unread 06-01-2008, 11:00
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: IR Sensors
By the rules, you can have as many IR Receiver boards as you want, as long as you do not use more than 4 commands total, so there is no reason to have more than one since you cannot use more than one.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 06-01-2008, 13:05
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: IR Sensors
you could have one on each end of the bot (front and back) so the robocoach will always be able to signal
...forest
Unread 06-01-2008, 13:29
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Re: IR Sensors
...forest
There are other solutions too that might, hypothetically, involve gyro, encoders, and servos....I really like StangPS
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 06-01-2008, 14:32
ccsingle07 ccsingle07 is offline
AKA: Cody Cannon
FRC #0830 (Rat Pack)
ccsingle07 is an unknown quantity at this point
Send a message via AIM to ccsingle07 Send a message via Yahoo to ccsingle07
Re: IR Sensors
If you can have as many IR sensors as you want. Does that mean you can have as many Remotes as you want. As long as there are 4 signals of course.
Unread 06-01-2008, 14:47
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
Rookie Year: 2007
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Re: IR Sensors
I actually would like to know if you could combing the output PWMs from 2 IR recievers (for front and back) in such a way that it does not violate first restrictions.. I mean, if a digital signal is just +5v to 0, why couldn't you just combine the digital pins? This way you don't have to burn 8 inputs..
Unread 07-01-2008, 21:30
tlawless's Avatar
tlawless tlawless is offline
FRC #0027 (Team RUSH)
tlawless is an unknown quantity at this point
Re: IR Sensors
Two things.
1. I believe the output from the IR board is simply a digital signal, not a PWM output (if you're unsure of the difference let me know, I'd be happy to explain!).
2. I don't think you'd be violating any rules by joining the digital inputs from two (or more) IR receivers. Just keep in mind that your digital pin would be exerted when either of the two boards receives the signal. This essentially doubles your chances for signal interference. Also keep in mind that you can use an analog input for a digital signal, just not the other way around.
Unread 07-01-2008, 21:49
Schooj's Avatar
Schooj Schooj is offline
FRC #0665 (MAYHEM)
Schooj is an unknown quantity at this point
Re: IR Sensors
As far as multiple boards for reception go, they are not necessary. I did extensive experimenting with these when they came out a few years ago and discovered that despite the "window" in the front, the whole sensor case is fairly transparent to IR. This may have changed though since that was one of the main problems of the original IR sensor.
"I reject your reality and substitute my own." -Mythbusters
Unread 09-01-2008, 08:50
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: IR Sensors
It is normally not a good electrical practice to directly wire 2 outputs together ... as one of them can drive a signal into the other. It can be especially damaging if the INPUT that they are connected to has a high impedance.
I haven't looked at these circuits specificially, but typically outputs don't like to get external excitation. It all depends on the type of output circuits ... and whether or not you add external circuitry to isolate/protect the drivers.
Will it work? Maybe. Will if fry the board? Maybe, maybe not. I'd have to look at the driver circuits to see if they have protective circuitry.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 09-01-2008, 10:04
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: IR Sensors
You can look at a techniquie called wire OR'ing. You wire two or more outputs together, but not directly as you indicated. It can be done with steering diodes, for example: tie all four outputs together through a wire OR into a single interrupt (port B pin). Each pin could also be directly tied to a generic digital input pin. Interrupt fires, then interrupt code reads the generic inputs. The purpose would to tie up only 1 interrupt pin.
Unread 09-01-2008, 14:28
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: IR Sensors
The First documentation says this device is an implementation of the aTinyIR2 device. The schematic for the TinyIR2 shows a PIC controller and implies that the outputs come from some tri-state pins on the controller. As such there is no way to know whether it is safe to "OR" the outputs of several boards together with simple wiring. It might be OK to use diodes but I am not sure it is worth the frustration of trying to troubleshoot two boards and get them working together.
http://www.tauntek.com/TinyIR2-schematic.pdf
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-01-2008, 23:29
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: IR Sensors
The manual clearly states 1 remote per team.
Unread 08-01-2008, 21:45
tlawless's Avatar
Re: IR Sensors
Out of curiosity, where does it state that you are only allowed 1 IR board? I ran a few searches through the manual and found nothing.
Unread 08-01-2008, 22:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: IR Sensors
I think the fact that the board is only available in the Kit of Parts, and only one of them is provided, clearly indicates that only one may be used.
This could change if the board became available for purchase as an off-the-shelf item.
  #15   Spotlight this post!
Unread 09-01-2008, 06:31
tlawless's Avatar
Re: IR Sensors
If you're not able to find additional boards thre's nothing stopping you from building a similar device. I haven't found anything in the rules that states that you can't use more than 1 of the supplied boards though, regardless of how difficult they may be to find.
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Sensors Joe_Widen Programming 12 25-06-2006 21:45
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
sensors edomus General Forum 5 19-11-2003 16:46
Sensors. Josh Hambright Technical Discussion 4 17-02-2003 11:08
