Go to Post It's easy to get overwhelmed. Don't get overwhelmed, just keep working at things a little bit at a time. (Oh, and don't forget to have fun!) - DominickC [more]
Unread 09-01-2008, 07:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: IR Sensors
R69 seems to be the definitive command although it is referenced by other rules. My boldface added...
<R69> Reaction of the ROBOT to communications received from the SIGNALING DEVICE must
meet all of the following criteria:
 For a single MATCH, the ROBOT shall be limited to react to a maximum of four distinct
commands
- either through hardware or software limitations, or a combination of the two.
 The ROBOT shall not dynamically change the recognized command set during a MATCH.
 The ROBOT may only seek out and react to permitted SIGNALING DEVICES belonging to
the assigned ALLIANCE (as defined in Rule <R65>). Intentionally reacting to other
SIGNALING DEVICES is prohibited.
See also R65 for specifics on the interaction with THE robocoach and size limitations. Additionally, R65 implies that the you are not limited to using the IR board.
<R65> SIGNALING DEVICES shall be designed to communicate signals from the ROBOCOACH
to the ROBOT. SIGNALING DEVICES are excluded from Rule <R64>. SIGNALING
DEVICES shall:
use either passive (no emission of any electromagnetic radiation) or active (emits some
restricted form of electromagnetic radiation) means of communication
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-01-2008, 21:54
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: IR Sensors
Originally Posted by popo308 View Post
The manual clearly states 1 remote per team.
can you tell me which rule says that? from what i read you can have as many as you want but only 4 commands can be used.
...forest
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Sensors Joe_Widen Programming 12 25-06-2006 21:45
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
sensors edomus General Forum 5 19-11-2003 16:46
Sensors. Josh Hambright Technical Discussion 4 17-02-2003 11:08
