Go to Post I betcha the FIRST officials in the know come in here from time to time and either gasp and think of how to make next year's clue harder or fall off their chair laughing. - Sparks333 [more]
Unread 06-01-2008, 20:40
Mike@1023 Mike@1023 is offline
Rookie
AKA: Michael Cononie
FRC #1023 (Bedford Express)
Team Role: Student
Mike@1023 is an unknown quantity at this point
Send a message via AIM to Mike@1023
Re: Top speed?
Originally Posted by David Brinza View Post
Speed of light is the fundamental limitation. Sonic booms would probably be discouraged. Most likely, safety will be the determining factor - a 20 ft/sec robot may be deemed unsafe by the referees if it behaves as if out-of-control.
Maybe this year a speed limit will be established, which would be an "interesting" development for the program. Radar guns!!!
A low center of gravity would help, although you COULD spin out as a result...maybe 20 ft/sec drive train is a little too fast?
My Team. 1023.
We're on year 6 and still doing great!
(And expect to continue to do great!)
Wish us luck in '08!
2007 Bedford Express Rookie, Build Team Member
2007 - GLR & Boilermaker Finalists & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award
2004 - GLR/DTR Semi Finalist
2003 - GLR Quarter Finalist & GLR/NAT'L Rookie All Star
Unread 06-01-2008, 21:14
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Top speed?
I think this year there will be robots exceeding 20 fps but these robots will also probably has sophisticated turning systems or eliminate the need to turn entirely (20 fps mecanum/holonomic/swerve). I think teams that used swerves last year may have an advantage the image of team 71 swerving around the rack at high speed sticks in my mind lol.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 06-01-2008, 21:20
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
Team Role: Leadership
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Re: Top speed?
Does anyone know if there's any rule about an unsafe speed or is that just a judge related matter?
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 06-01-2008, 21:28
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Re: Top speed?
Seems like a decent way to take the turns...
Unread 07-01-2008, 11:48
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
Rookie Year: 1999
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
Re: Top speed?
I scrolled through the manual, but I didn't see a specific rule.
Generally, the refs judge "unsafe speed" based on whether or not you have control over your machine. If you're going flying into walls, if you keep heading toward the outside of the field, if you're ramming into other robots, be prepared to be deemed unsafe.
But as long as you seem to VISIBLY have a handle on your machine and what it's doing, then you should be fine.
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 06-01-2008, 21:24
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Top speed?
While I agree that you will see many robots going faster than 20fps, I doubt very many teams will do well that go that fast. The reason I say that is because winning races has more to do with control than speed, especially on a short track such as FIRST has provided.
No. I believe that this year the winners will be the robots with the best control over their drive system and the robots that can take the big hits from those that cannot control their drive systems.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 07-01-2008, 14:47
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Top speed?
This makes me chuckle a little bit. Last year, we had a 7fps crab system. Driving full forward and doing a 90 degree crab maneuver put a ton of stress on the drive modules. We cracked the hubs on quite a few wheels due to the tremendous side load. I can only imagine what would happen if the wheels of a robot moving 20fps were suddenly turned perpendicular to the direction of travel.
Unread 07-01-2008, 14:51
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Top speed?
As I remeber hearing once. I don't care about the car that goes 0-55 inn 2.5 seconds. I want the car that can go from 80 - 50 in 1.2 seconds. It's not gonna just be how fast you get around the straightaway but can you survive the hairpin turn.
Unread 07-01-2008, 15:02
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Top speed?
Going around this turn reminds me a lot of autonomous mode of 2003, some teams would steer (mine included) and some teams had tank but would have wheel lowered on an angle that would steer them around the corner then bring it up into the chasis (312 did this and a few others but I can't remember them now)
Penn Class 08
Unread 07-01-2008, 15:10
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Top speed?
This is somewhat related to the topspeed discussion so I figure I'll ask it here. When determining the "top speed" of a robot in relation to it's gearing, wheels, motors, ect. what point on the motor curve are you taking the RPM numbers from? My team is a second year team with little or no help from any Mech E's and we are looking to do a bit more in terms of drivetrain design than we did last year.
So when someone says they have a 15fps or 16fps robot what RPM is that on the motor (assuming 2.5" CIM)?
Unread 07-01-2008, 15:34
RobJ RobJ is offline
FRC #0254 (Cheesy Poofs)
Team Role: Teacher
RobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of lightRobJ is a glorious beacon of light
Re: Top speed?
It depends on the size of your wheel. If you go 16 fps with 8 inch wheels then your motors will be rotating twice as fast at 16 fps with 4 inch wheels
Unread 07-01-2008, 16:11
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Top speed?
I can easily see teams doing laps under 10 seconds with a great line of travel, and no interference.
Whether or not this will happen is to be seen.
But it can, which to me is pretty darn awesome.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 07-01-2008, 16:12
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Re: Top speed?
It also depends on the team reporting that speed. Relatively few teams measure actual speed (I think the Martians do, but beyond that I can't think of anybody). So, then you get into theoretical calculations. Some teams approximate inefficiencies (JVN's famous .81% of free speed is an example), some just use the 12V free speed, and some report numbers based off of operation at 40A draw.
I wouldn't use the 40A one, because most of the time you aren't going to draw that much just driving around, and if you are you're probably in trouble. (40A per motor doesn't leave much wiggle room at all on either the motor breakers or the main breaker) Similarly, I highly doubt teams will be driving with their motors running at 12V free speed; however, there is something to be said for the argument that the battery doesn't output 12V, more like 13.5ish, and that can make up for some of the inefficiency losses. The approximation method may end up more accurate than either of the above, but that is obviously dependent on how accurate the inefficiency approximation itself is.
Personally, I just use free speed in calculations because it is easier to work with. In my experience, underestimating speed has worse consequences than overestimating (to many interrupts per sec, dead-reckoning autonomous driving too far, etc). Whatever you choose stick with one; you can then compare speeds year to year much easier than if you had to convert from one method to the other.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
pic: Back-in-Black 4-speed Top View unclewaldo Extra Discussion 10 11-04-2013 00:40
Letting robots on top vs getting on top of robots sanddrag Rules/Strategy 44 09-02-2007 10:50
pic: Top Gun Top Wheels Rick TYler Robot Showcase 4 04-02-2006 11:13
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Top Speed Victim of Fate Technical Discussion 43 16-12-2003 22:10
