Go to Post The only dumb question is the one you don't ask. - E. Wood [more]
  #16   Spotlight this post!
Unread 07-01-2008, 08:42
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Team Role: Leadership
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
Re: Toughbox Assembly Video on YouTube
Originally Posted by rmlondon View Post
How do we mount the CIM and the Transmission box? Any suggestions?
Rob
Team 2116 RobotFutures
Good question. I was wondering that as well. Based off the CAD drawings and not physically having the materials in front of me I couldn't figure out how the plates get attached to the transmission. I plan on tinkering around with the parts to figure it out but if anyone has already mounted it and has some hints that would be appreciated.
Also, is there any suggestions on how we can interface the transmission with a encoder? We haven't had much luck with the gear tooth sensors and really liked the encoders that were on the Banebots Xmission last year. Any suggestions out there for a Andy Mark compatible equivalent?
Many Thanks!!!
  #17   Spotlight this post!
Unread 07-01-2008, 09:07
Unsung FIRST Hero
Waynep Waynep is offline
217 Alum, Former 395/348 Mentor
FRC #1923 (MidKnight Inventors)
Rookie Year: 2000
Waynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond repute
Andy,
Great video and great product as always! Thanks for taking the time to put this instructional video together for our younger teams. Please thank all of your product assembly instructors as well.
PS so in this video i noted why i have had trouble during assembly and what my teams have been lacking during build season: BACKUP DANCERS
thanks again for showing us all the way
395 2TrainRobotics
Regional Champs- '03 VA, '05 PIT, '05 NY, '06 PIT, '06 NY; Regional Finalist- '04 NY; Engineering Inspiration- '03 NY, '06 PIT; Regional Chairman's Award- '04 NY
348 Norwell Robotics
2008 NY Regional Finalist; 2008 Curie Division Champs; 2008 World Championship Finalists
1923 MidKnight Inventors
2009 NJ Regional Champs; 2010 BOS Engineering Inspiration Award; 2011 CT Regional Champs, Gracious Professionalism Award, Coopertition Award
  #18   Spotlight this post!
Unread 07-01-2008, 14:38
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Because I seem to have missed this, and don't know too much about gearbox terminology (I'm ashamed to admit), What is the output shaft speed on a Toughbox when combined with say the CIM motor from the KoP?
I'm not sure of the output speed of the CIM motor either as of right now.
The 12.75:1 ratio is related to that magic end number but how?
Thanks to anyone who will take a moment and explain this.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
  #19   Spotlight this post!
Unread 07-01-2008, 14:45
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Team Role: Coach
Rookie Year: 1996
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Hi Elgin,
The Toughbox reduces input speed by 12.75 times. To find the shaft speed you take the input (CIM) speed and divide by 12.75.
Shaft speed = input speed / 12.75
The input speed depends on alot of things such as fiction, load and voltage applied. The CIM at 12 volts and no load is roughly 5000 RPM (off the top of my head).
If you are interested in how different voltages and loads can change the output speed, I would strongly suggest checking out the JVN design calculator sheet that is posted in the white papers section.
Best of luck,
RAZ
  #20   Spotlight this post!
Unread 07-01-2008, 14:51
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Another nifty CIM number to remember is 88.5 rev/s. In the past, the FIRST documentation has rated CIM free speed at 5310rpm; if you divide by 60, you get 88.5rps. Knowing that number makes calculations with CIMs much quicker; how often do you measure mechanism/drivesystem speed in terms of something/minute? I would (probably) be willing to wager that it is much less often than measuring in something/second (ft/s, deg/s, m/s, etc). If you just remember 88.5 then you can skip dividing by sixty in your calculations, saving time. Especially useful if you're sitting in the middle of Psychology and you feel a need to run some drivetrain numbers and lack a calculator.... only a big nerd would need to do that though Yes, I know I should stop doing it, but it's so fun!
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
  #21   Spotlight this post!
Unread 07-01-2008, 15:00
Awesome. Thanks!
I figured it was as simple as that (in a simple calculation based world that is anyways ignoring friction, stalling, etc, etc..) but just wanted to be sure.
  #22   Spotlight this post!
Unread 08-01-2008, 10:03
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Many Thanks!!!
To attach the transmission mounting plates to the transmission you need to take off the lower two bolts in the Toughbox (loosening the top two would be good also), align the two hole on the transmission mounting plate, the smaller of the plates provided, replace the bolts in the holes, put nuts back on and tighten all 4 bolts accordingly. Then, use the given hardware to attach the transmission with mounting plate on to the kit frame. The slot areas will allow for tweaking of chain tension and/or placement of output shaft for a live axle system.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
  #23   Spotlight this post!
Unread 08-01-2008, 10:39
The Spiky Hair Guy
Great thank you for the clarification! Much appreciated!
  #24   Spotlight this post!
Unread 08-01-2008, 13:30
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
At the risk of looking like an idiot, am I the only one who can't spot the yellow truck?
Great video!
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
  #25   Spotlight this post!
Unread 08-01-2008, 13:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Don't feel bad. If it's where I think it is, the truck is only clearly visible for about three frames, and it's moving so fast that it's difficult to identify its shape.
  #26   Spotlight this post!
Unread 08-01-2008, 15:10
Kyle Love's Avatar
Team Role: Teacher
Great video!
The yellow truck is hiding in the pyramid of Gen 2's at the beginning. It got lost somewhere in the middle due to second third and more takes, and kids (including Nick and I) that wanted to play with the infamous yellow truck.
Kyle Love
Teams I've been on:
Toughbox mounting bracket models Rob CAD 2 10-01-2008 11:34
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
Online youtube video sessions anyone!? :D Testament-Doom 3D Animation and Competition 7 10-12-2007 22:14
Youtube Video contest Rick-906 Championship Event 7 17-04-2007 20:35
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
