Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 07-01-2008, 01:32
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Loophole?
Hey, when you "accidentally" knock another alliance's trackball out of the ring, they said they'll replace it "when it's safe." Do you think they'll stop the clock to do it, or will this be an evil way to burn time?
Oh, and I'm not evil enough to think of this, it was my friend. It's not even close to gracious professionalism. And we're a Christian school, for goodness sakes.
Unread 07-01-2008, 01:36
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Re: Loophole?
i doubt they will stop the clock to put the ball back in, but as you said it is very against the spirit of the competition. Additionally, it seems that it would be rather difficult to force a ball out of the field without possessing it, and thus incurring a ten point penalty.
http://www.wcsrobotics.com
team 663
team 1493
Unread 07-01-2008, 01:46
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Loophole?
It'll also be pretty obvious if you are continuously dumping balls out of the field.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 07-01-2008, 02:24
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Loophole?
They will not stop the clock. This has been seen in many years gone by, and although this is one of the few years with a limited amount of scoring objects as opposed to say last year with a plethora of tubes available, the "when it's safe" statement will be when someone (most of the time a field reset crew member) can grab the ball from wherever it's rolled or bounced to off the field, and put it back into play.
Note, the balls will not be put back on the field at any specific entry point, but more often than not when I myself as a field reset crew was responsible for something like this in the past, I had put it back in as close to where it left the field without endangering myself by reaching into the field next to/ or near a robot.
Be assured they will be put back into play randomly placed, and as fast as possible, and if you see this happening, don't try to drive your robot to where you think the field crew would be putting it in, just give them room to put it in, and then continue to go try and catch it and play as normal.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 07-01-2008, 10:19
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Loophole?
With the taller walls around the field this year, I suspect most balls will be reentered at the field gates.
(since 2004)
Unread 07-01-2008, 10:49
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Loophole?
My guess is that they will have an additional supply on trackballs on hand if replacing the current one will take too much time. I think they'll just basically throw or lightly toss the trackball back into the field in a random spot.
As for intentionally knocking balls out of the field, I can imagine a penalty if it's done frequently or obviously not a mistake or robot error.
This is a good question though as there are only 4 balls on the field....perhaps someone should q&a this?
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 07-01-2008, 10:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Loophole?
Your valuable match time might be better spent hurdling your own balls, if you have a machine capable of intentionally tossing balls out of the arena!
Unread 07-01-2008, 14:21
shinigami473's Avatar
shinigami473 shinigami473 is offline
Head Captian, Mech. Leader,
AKA: Brent Pugh
FRC #1510 (Westview Robotics)
shinigami473 is on a distinguished road
Re: Loophole?
Why waste the time to try to get you opponents balls out. This game is supposed to be very offensive, so you should redirect resources into getting points for yourself. The game is not going to be won based on who prevents more scores, but who can score better.
Head Captain, Mech. Leader
Unread 07-01-2008, 13:56
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Loophole?
Likely--though the manual does say something about "as close as possible to where it left the field."
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-01-2008, 13:58
akash155 akash155 is offline
Akash
FRC #0540 (Team 540 Screaming Eagles)
Team Role: Tactician
akash155 is on a distinguished road
Send a message via AIM to akash155
Re: Loophole?
<G30> specifies that "The TRACKBALL will be placed at the approximate location where it exited."
Unread 07-01-2008, 18:16
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: Loophole?
If you knock it out of the ring, the reset team will probably not put it back in the track from outside the field. The will probably put it back in near the forward movement friendly field entrance when its safe. Putting it back on the overpass is not easy and may conflict in scoring.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 07-01-2008, 18:48
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Re: Loophole?
Referees aren't fools. They will notice that it is your strategy after a couple times.
Judges will do the same and will see your team going gainst the ideas of gracious professionalism.
This is not a strategy which you would be proud to say you rode all the way to a gold medal or even a win.
Finally, "Loopholes" are probably not left there on purpose by the GDC, especially in this case. GP rocks. Embrace it.
Robocoach signals loophole? jacobhurwitz Rules/Strategy 51 29-01-2008 09:16
Autonomous user-input loophole? Jeff McCune Programming 20 14-02-2003 22:44
