Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 07-01-2008, 03:59
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Team Role: Mechanical
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
rule question on scoring above overpass
my idea is that it would be fast when trying to score, to place the ball on the overpass, then drive under and retrieve it from the top of the overpass. I think this will be easier than trying to track the bouncing ball back down. Does anyone see anything questionable about this rule wise?
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 07-01-2008, 04:27
Billfred's Avatar
Billfred Billfred is offline
Re: rule question on scoring above overpass
From the manual (which is quality reading, lemme tell you), emphasis mine:
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
Unread 07-01-2008, 04:29
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Originally Posted by Billfred View Post
I suppose it would help you a bit if the action you described was an allowable form of hurdling. From the manual (which is quality reading, lemme tell you), emphasis mine:
Thanks Billfred. I had heard a rule about touching the Trackball existed, and was reading up on it, but couldn't find it.
Thanks for that manual quote.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 07-01-2008, 07:01
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
But, while the trackball is sitting on the overpass it hasn't yet CROSSED. So is the second-touch rule in effect yet?
(since 2004)
Unread 07-01-2008, 08:55
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Originally Posted by <G22>
Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
You also run into rule G22. If you reach back to grab the ball, you'll be crossing the line in the clockwise direction.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 07-01-2008, 09:57
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
um you can definitely work around that just make you manipulator work above your robot
i.e. put the ball on the over pass
and move foward ( cross the line for two points yessssss!!!!!!!! more points) and reach back w/o moving your entire robot back
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 07-01-2008, 10:18
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
So at what point do you actually have to release the ball?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 07-01-2008, 11:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I suspect you are doing gyrations that are not necessary. As someone else said, we need clarification from First.
1. Can you touch the ball while hurdling it through the start/finish plane
2. Can you break the plane from the non-home stretch side of the field with your gripper to knock the ball off in hybrid
Unread 07-01-2008, 12:25
tbd tbd is offline
FRC #1577
tbd is on a distinguished road
We have a simmilar dilemma:
What actually is considered a hurdle?
^ is that really a possibility? Is putting the trackball on the overpass and just pushing it off again considered a hurdle? Can the ball even touch the overpass when its hurdled?
And then ofcourse can you touch the ball during the hurdling?
Unread 07-01-2008, 12:36
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
Team Role: Coach
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
I think the robot cannot be touching the trackball at any point while the trackball breaks the plane of the line. Therefore when the ball is on top it has been touched while entering and leaving the plane if it is sat up there then grabbed off.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 07-01-2008, 12:58
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
bah, nvm, I see the big conflict.
Keep in mind they mean for a CROSS to have a vertical projection, e.g. from a bounce or from launching it. No matter how I twist this in my head it seems the grey area is whether or not the "vertical projection" must happen before the trackball breaks the plane of the finish line or if it is still scorable to give the ball a vertical projection after it breaks the plane but before it has fulled CROSSED.
GitHub
Unread 07-01-2008, 13:37
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
The rules seem to indicate that you must let go (not be in contact with) the trackball sometime before, during or after it completely crosses the finish line once you do whatever it is you do to get it over and to count it must touch either the floor or another robot before you touch it again.
When the trackball is completely past the finish line, if you have not all ready let go of it, you must do so now. Then, before you touch it again, it must touch either the floor or another robot.
Unread 07-01-2008, 20:22
jediptm jediptm is offline
AKA: Pete Mueller
FRC #1701 (RoboCubs)
jediptm is an unknown quantity at this point
Based on the definition from the rules:
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
Above would seem to me to mean you can't set the ball on the overpass, then knock it off. When you add this to the scoring chart that says you get 0 points for knocking a ball off the overpass during the teleoperated period, I am pretty confident this would not count as a hurdle.
Unread 07-01-2008, 14:26
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
...And have a 10-point penalty for re-crossing the line (breaking the plane is counted as re-crossing), giving you a score of zero for the maneuver and a loss of time as you must go around again.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #15   Spotlight this post!
Unread 07-01-2008, 09:09
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
this is very tricky.
because your trackball is now resting on the overpass, part of the ball extends past the finish line. if you now dislodge the ball, using your robot then you get no points, since you are touching the ball while it is crossing the line.
you get no 2-point score nor the 6-point bonus. however, if you pull the ball back from the overpass, and then hurdle the ball correctly, the score should be given.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Question on rule S03 colt527 Rules/Strategy 2 10-01-2006 20:18
pic: Galileo from above...WAY above! CD47-Bot Extra Discussion 8 21-04-2004 14:22
Rule M7 Question Stephen Kowski General Forum 2 13-02-2003 14:00
RULE Question. archiver 2001 7 24-06-2002 00:38
rule question.... archiver 2001 1 23-06-2002 22:54
