Go to Post The only thing "an eye for an eye" has ever settled is two eyeless people. - Cory [more]
Unread 07-01-2008, 10:18
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
Team Role: Mechanical
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs
Greetings fellow mech-maniacs.
Our team is in somewhat of a pickle this year, since we can't quite agree on what would work best. I've presented the concept of a 4-bar lift (used in some heavy industrial forklifts), which would be capable of lifting the ball to overpass level via worm-gear or lead-screw, and then releasing it to complete the hurdle.
We are also debating the use of a scissors-lift, although I am not very fond of them because of the large amounts of force necessary to lift them from compacted positions, and starting them from semi-open positions means they are taller.
We were thinking about using an angled crane which sloped back over the robot, potentially mounted on a scissors lift to carry it the extra few feet to the overpass, but I think that might be rather complex, and we've had bad experiences with complex machinery.
Finally, we were thinking of a combination of a 4-bar lift and a gas-spring. The lift would center the ball over a motor-wound gas-spring, which would then fire and kick the ball over. I'm skeptical about it, because our '06 tests showed that pneumatics and the like were barely capable of firing a poof-ball, let alone these new trackballs.
Any comments to help settle the predicament would be VERY welcome!
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 07-01-2008, 10:27
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs
Can you build some quick mockups to test some of the different ideas?
Unread 07-01-2008, 11:34
Hiteak's Avatar
Hiteak Hiteak is offline
Improving the Technology World
AKA: Dan Schneiderman
FRC #3157
Hiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond repute
Send a message via AIM to Hiteak
I would not recommend doing a scissor lift. We did that for last year and it was really slow.
RIT '13
Computer Science House Member
Working towards improving technology policy
Student: Team 1930, 2005-2008
Mentor: Team 2999, 2009
Ruckus: 2006 -2010
Volunteer:
NJR: 2008
FLR: 2009, 2010
Unread 07-01-2008, 11:53
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Not all scissors lifts need be slow. Team 639 built a scissors lift that could extend to grab "the bar" in about one second back in 2004. http://www.team639.org/index.php?page=r2004
What was more impressive was that it did this from a fully collapsed state. Anyone from 639 care to give some specs on how you did it?
Jason
Unread 09-01-2008, 22:19
sethw sethw is offline
FRC #0639
sethw is an unknown quantity at this point
Jason
We were able to build a very fast pneumatic scissor lift in 2004 using two 1.5" bore pistons. I'm not sure of the exact stroke length, but I know it was somewhere around 10". The lift itself was made of 1" square tubing members with occasional cross braces. However, the system we created was not very sturdy, and was meant to be used more than once in a match. Ideally, it would never be dropped back to its retracted position using the pneumatics - doing so sent it crashing down extremely quickly. It would be possible to prevent this, but the entire assembly was fairly fragile, and we ended up bending and having to replace nearly every part of the lift at least once over the course of two regionals. That was without lifting a load. Also, the pistons we used had to be very large to give us enough force, meaning it drained our air tanks to about half pressure every time we used the lift. Granted we are able to use twice as many tanks this year, but it is still a significant amount of air for a single lift. With modification, it may well be possible to create a similar system able to be used repeatedly - that is one possible design our team has considered. However, we've come to the conclusion that there are definitely better solutions.
Unread 10-01-2008, 11:46
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
Team Role: Leadership
bobdahaxor is an unknown quantity at this point
when you decide what you want to do, think about the weight of the ball. The ball is 10 pounds and 40 inches in diameter. that is quite heavy. If I were you,I would make a list of the pro's and con's of each type and then make a list of what you want your arm to do. Then compare the pro's and con's list to the list of what you want the robot to do. Besides that, I want to warn you that scissor lifts are extremely hard to properly manufacture. I also did the math for the spring (gotta love physics 201 and oscillation's and elasticity) and pushing or punching the ball is out of the question. There is not enough of an impulse to do so. I have a hint though (or for what I think is a good idea). That 8020 you got in the KOP is more than likely just sitting there. It can easily be used as more than just a square tube.
Unread 10-01-2008, 15:07
Storm Storm is offline
FRC #1619
Storm is an unknown quantity at this point
My Team did a Scissors lift in 2005, it worked, but it took massive amounts of time and most of it had to be custom machined by one of our sponsors. It took a huge ball screw to actuate and we had a high CG. on the other hand it won the Engineering Inspiration award. Here is a picture.
After that we have the "no scissors" rule like many of the other teams.
Unread 11-01-2008, 21:47
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
After a week of brainstorming and prototyping..we're thinking hard about a chained lift. The only time we've ever done a scissor jack lift was the '99, Cyber Blue's rookie year. We did a chained lift in 2005 for lifting the tetras and we think it will work quite well for this year. I think the biggest thing this season will be how you grip the ball really. I mean it really doesn't matter how you get it up there as long as it works and its fast. I think the real matter is once you get it up there, can you place or throw the ball? Will the gripper/holder make it too top heavy?
Unread 20-01-2008, 17:09
graymorr graymorr is offline
FRC #0614
graymorr is an unknown quantity at this point
Any chance to get more pictures or drawings of your 2004 scissors lift. You have brackets on there for some reason(s). Gray
Unread 07-01-2008, 11:56
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
I have been curious as to exactly how much force it would take to launch a ball 10 ft at a 60 degree angle. ( for about 7ft high and between 5 and 7 ft horizontal from overpass.) I think arms and lifts are going to be too slow.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 07-01-2008, 13:13
AKA: Jason Brett
Take a look in your physics textbook for kinematics formulas. The math to solve these types of problems is quite simple and is a common part of the Physics 11 curriculum here in BC. My estimates are that to launch the ball six and a half feet (roughly 2m) requires an accelleration of 2g over a distance of 1m.
In other words if you have 20lbs of force behind the ball for about 40" you should be able to get it to go 6 1/2' straight up from the last point you contacted it. To account for your desired 60 degree angle, take a look at breaking a vector down into orthogonal vectors (ie, how much "up" and how much "over" you will need). These are actually quite useful formula for many types of questions and are not that difficult to use and understand.
Jason
Unread 07-01-2008, 15:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Never use scissors lifts is a cardinal rule on our team.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-01-2008, 15:46
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
we used a scissor lift in our 04 year that was plenty fast but it wasn't strong
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 07-01-2008, 15:50
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
For our team too.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
  #15   Spotlight this post!
Unread 07-01-2008, 15:56
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
4 Bars With Gas Springs have been used before, and quite effectively. However I feel like not in the way your describing.
http://www.chiefdelphi.com/media/photos/26796
http://www.chiefdelphi.com/media/photos/21477
http://www.chiefdelphi.com/media/photos/27982
Thats 1902, 1369, 217 in 2005, 2056 in 2007 just a few examples that I can think of.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Is shipping gas springs via air freight safe? Madison General Forum 3 21-02-2007 20:49
Gas Springs Legal? JoeXIII'007 Rules/Strategy 17 30-01-2007 23:47
using gas springs? needed? ajlapp Technical Discussion 2 20-01-2005 21:25
Gas Springs Allowed ? Dave Garnett Pneumatics 6 20-01-2005 13:37
