Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 07-01-2008, 10:20
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Lightbulb Team 1527 Chassis/Electrical/Pneumatics Design...
Well since the season started i set my students loose in Inventor again, and between our 3 groups we have come up with this base design, there are still some things missing but there is plenty of room, when we get the arm/actuator designs done ill post them as well.
-Design View Number 1-
-Design View Number 2-
-Design View Number 3-
Also we used the KOP Transmission in the design simply because we don't have our 2-speed transmission drawings at the moment till we get them off a busted comp :/
tell me what you think of it
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 07-01-2008, 11:01
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Team 1527 Chassis/Electrical/Pneumatics Design...
I jealous! That's some good looking and fast work!
We haven't even discussed what type of drive train we are going to use - we spent Saturday doing inventory and get the controls system wired and running on the test bench.
One suggestion - if you moved the cims and gearboxes to the empty space in front, and put the compressor between them, you could drop your electronics board down significantly, distribute the weight more evenly, and lower the entire center of gravity of the machine. I think that is going to be an important consideration this year.
Unread 07-01-2008, 11:09
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
any ideas for the material that you are going to use for holding your spikes victors, etc.?
BTW Looks awesome and how quickly you got it done is Amazing!
Unread 07-01-2008, 14:25
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Cameron,
The only thing I see that stands out is the distance between the terminal blocks, breaker panels and speed controllers. Length=loss so a prudent design would be to move things to be more direct and closer for these high current devices.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-01-2008, 14:50
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I would like to see some "shielding" for the speed controllers as well as the spikes and some of the other electronics. You don't want these expensive mandatory pieces of equipment breaking in your first match because your electronics were in the line of fire.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 07-01-2008, 16:25
AKA: Cameron Dennis
the placement was thought of carefully, with the arm we are going to use we looked at weight and COG.
the victors/spikes are mounted on 1/4" polycarb strips
the distance is actually really close the only thing we might do is mount the din rail on the bottom of the electrical/pneumatics box, that way all electrical is with in a 12x12x12 area except of course for our actuator motors
As for protection we are going to have a shell over this all so that wont be a issue
www.frc1266.com
Unread 08-01-2008, 20:57
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Those are some really nice drawings! I'm really impressed by your team's work. The only thing I might comment on: those look like strips of Lexan on the outside of your chassis. Are you cantilevering your wheels and simply using the Lexan for lightweight protection or do you plan to support the shafts by drilling holes in the Lexan and fitting them in? I can't really tell from the drawings. We used Lexan outer plates to support shafts two years back and had a horrible time with them flexing. We thought that it might save us some weight, but it just ended up being a big pain. Since then I think we've limited our use of Lexan to covers and mounting plates for electronics.
Just a thought!
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 08-01-2008, 21:24
AKA: Cameron Dennis
they are just for lightweight protection, not supporting at all
www.frc1266.com
Unread 08-01-2008, 22:24
CidTeach CidTeach is offline
Mechie
AKA: Mr. C
FRC #0334 (Tech Knights)
Team Role: Teacher
CidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really niceCidTeach is just really nice
Just a question for you's guys - how/what is the best way to mount the BaneBots dual CIM motor tranny directly to the aluminum IFI rims(those multi piece really expensive rims with the riveted rubber tracks)...
Im trying to avoid machining little parts for that connection.
perhaps a slotted sleeve to mate with the output shafts keyway?
thanks
Unread 09-01-2008, 01:38
AKA: Cameron Dennis
thanks
So your using a banebot transmission from last years kit with the 2 cim modification?
or are you talking about the 2008 KOP transmissions?
and your mounting these ..
to the output shaft of the transmission, correct? Well what we did last year was we used a small sprocket that had set screws to replace one of the bearings on the wheels, what i would suggest would be to make a keyed hub that bolts to the wheels it would work better then set screws and you wont need to use loctite
www.frc1266.com
Team 20 Chassis rjbarra Robot Showcase 0 18-02-2007 15:41
pic: 1323 Chassis and electrical Robo_Coyote Extra Discussion 8 20-01-2007 21:32
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
Team 820 Chassis MBosompra Robot Showcase 6 16-02-2004 21:46
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
