Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 07-01-2008, 10:25
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Interfacing with LCD to debug
Originally Posted by keen101 View Post
I am interested in possibly using an LCD for real time "debugging"/errors
Is this possible/feasible? Would we have to "steal" the old camera TTL port?
i know Kevin Watson mentioned interfacing an LCD on his website briefly, but i think he meant it as kind of a joke.
Originally Posted by Kevin Watson View Post
With regard to LCDs, I've used the seetron.com text displays and the earthlcd.com graphical displays on various 'bots over the past few years.
-Kevin
OK, I'm still very interested in this. I would like to know:
1. HOW to interface an LCD to the robot. (TTL port?) I really need to know how to wire it to the robot.
2. how to talk to the LCD in programming.
*note that I'm not a programmer, but I can relay the information to our team programmer. So, an idea or some sample code would be helpful.
Unread 07-01-2008, 12:21
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Interfacing with LCD to debug
Here's a demo example we used on a Vex robot a couple of year's ago: http://team358.org/files/programming/Vex_LCD_Demo.zip
The particular LCD we used was wired to digital input 16 and didn't use either serial port. It was a lesson on the basics of serial communication.
The README.txt file talks about the communication.
We used a Scott Edwards Electronics, Inc.
BPP-420 is an LCD module with attached serial interface. The spec. is in the zip file.
Last edited by Mark McLeod : 07-01-2008 at 12:32. Reason: NOT wired to the Vex TTL port
Unread 07-01-2008, 12:25
keen101's Avatar
Ubuntu Linux User
Thank you. That may come in very handy.
Unread 07-01-2008, 12:35
Just Itinerant
Sorry, I had to add a P.S. to my post.
The example was used as a lesson on the basics of serial communication and didn't use either serial port. It used a single digital output pin to transmit serial data to the LCD module.
If you use the TTL port instead then you can take advantage of the built-in serial support.
Unread 07-01-2008, 12:39
keen101's Avatar
Ubuntu Linux User
Yes, since there is no camera this year. (or at least no camera is really needed to track a green light) Then, I am thinking about "stealing" the port and use it for a cool LCD. Hopefully we can come up with a neat way to display errors, for real time debugging. But, it could at least display our team number.
Unread 07-01-2008, 17:13
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
I'm not too familiar with the processor in the RC but I use USART for my hobby projects. I just send a string to a for loop and it transmits at a specific baud rate.
Unread 07-01-2008, 19:31
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Spark Fun Electronics has a bunch of LCDs available. If you look for the ones labeled "serial enabled", then it is trivial to connect them to the FRC controller, or a Vex controller. Then you just use the "print()" function (making sure it goes to the right serial port) and whatever you print out shows up on the controller. There are a few escape sequences you can print to do things like clear the screen or move the cursor around.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 07-01-2008, 20:51
Have you successfully changed the splash screen on one of SparkFun's serial LCDs?
Unread 07-01-2008, 23:41
keen101's Avatar
Ubuntu Linux User
Ok, I think I am going to either get this one
http://www.allelectronics.com/cgi-bi...W-GREEN)_.html
or this one
http://www.allelectronics.com/cgi-bi...ACKLIGHT_.html
Does anyone know how to wire it up? I have no idea which pins go where. This is my first time working with LCD's. Now that I have chosen a specific model I'm hoping someone can help me out.
Unread 08-01-2008, 19:01
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
i have a more general question...how can i write and send a text command to the built in TTL port on the rc? without going into detail, a GPS reciever using the standard NMEA protocol accepts TTL ASCII text strings as commands, and sends the serial amswers back...how would i go about reading and writing from the TTL port like this, or at least use a digital pin to do this?
Unread 08-01-2008, 19:59
ay2b's Avatar
AKA: Andy
FRC #2928
Rookie Year: 1994
This depends on your code. If you are using Kevin's serial_port.c/h library, then the instructions are in the file. Basically make sure you have ENABLE_SERIAL_PORT_TWO_TX defined for writing and ENABLE_SERIAL_PORT_TWO_RX defined for reading, and have the appropriate baud rate set. Then you set the global variable "stdout_serial_port" to the value of "SERIAL_PORT_TWO". After that, any printf() will go to the TTL line instead of the debug line. Please note, however, that it's possible I'm getting ports ONE and TWO mixed up.
Interfacing a digital compass with the RC Kelly Electrical 14 27-09-2007 19:01
Interfacing with Allen-Bradley Sensors doubleslash Electrical 9 31-01-2006 14:11
SERAL INSTEAD OF DEBUG... EGG0900 Programming 2 05-11-2005 18:25
Interfacing a PC with last year's Robot Controller punarhero Technical Discussion 2 21-04-2004 00:05
Debug function in programming? archiver 2001 4 24-06-2002 00:34
