What do you guys think of the bumpers? I think it really limits the options that your robot has. Such as: no fork lift, no ramp, no wheels outside the chasy, and it is really hard to make a good shape for herding the ball a.k.a. a V shape. Bumpers are the curse that will break me in a puddle of brain goo. I have trouble making good combos with bumpers.
Re: Bumpers
For starters, bumpers don't have to be on all sides of the bot--just 2/3 of it. That means you could leave the front open. We cantilever our wheels every year, and we still plan on doing the same this year--it just means your bumpers need to be kept from being pushed into your wheels. |
Re: Bumpers
there just a certain way you have to do it...they almost messed up my design though.....
Re: Bumpers
Shouldn't be a problem. We've been able to use them for two years now, and if you did use them both years you know how to make them around your robot design.
Re: Bumpers
Remember that only 2/3eds of your robot needs to have bumpers.
Re: Bumpers
I think that bumpers will definitely be needed a lot during the game. Unless everybody is going to design their chassis based on stress management then, robot chassis will be very beat up by the end of a just a few rounds. With robots trying to race around a track as fast as possible, people are very very likely to bump. I also hope that people have more than one speed because trying to "lightly bump" to move ahead will turn into collisions if everybody is going at top speed.
Re: Bumpers
Does anyone know if any teams have ever used bumpers on a flat plate drive system? If so how are the bumpers attached.
Re: Bumpers
The bumpers are only required to go around 2/3 of your robot. If your robot is designed to the max footprint of 28" X 38" then 44" of your robots footprint could be unprotected. That's quite a bit of room to work with IMO.
Re: Bumpers
how do we know what bumpers are FIRST certified?
#10
Re: Bumpers
How to build the bumpers are in the rules somewhere they are really easy to make.
#11
Re: Bumpers
The guidlines for making bumpers are in the Manual under The Robot section.
And as a side note, that is a rather obnoxiously large signature picture. Please change it per the rules of the forum. Thanks. Quote:
#12
Re: Bumpers
Rule <R08> in The Robot, Section 8 of the 2008 Game Manual has all the proper dimensions for the only legal robot bumpers.
Re: Bumpers
The rules show a 3/4" plywood backer on the bumper. My question is can we lighten the bumpers by removing material or drilling holes in the plywood backer as long as it remains 3/4" thick (mostly)?
#14
Re: Bumpers
The weight is not counted in the 120lbs and you want as much weight as possible down low. |
#15
Re: Bumpers
But you only have 15lbs for the bumpers and the less weight on your robot the faster it will be.
| RE: bumpers | archiver | 2000 | 0 | 24-06-2002 00:13 |
| Bumpers | archiver | 2000 | 2 | 23-06-2002 22:48 |
| Bumpers? | archiver | 2000 | 3 | 23-06-2002 22:32 |
| Bumpers | archiver | 2000 | 0 | 23-06-2002 22:32 |
| bumpers | Martin | Rules/Strategy | 2 | 13-01-2002 21:51 |
