Go to Post FIRST is not about lowering the bar to those with the smallest expectations, but helping helping all teams exceed the standards set by the best. - Allison K [more]
Unread 07-01-2008, 17:32
zzz zzz is offline
FRC #2037
zzz is an unknown quantity at this point
Sideways Driving
Well i was thinking that since these balls are so big we could drive our robots sideways so that we would be 38" wide and 28" long. I have not seen anyone else who has done it in previous years so I wondered why and searched the rules and did not find anything. Please help cause it would definitely help my design lift the balls and would probably give you more options.
Unread 07-01-2008, 17:35
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Re: Sideways Driving
My team last year used a "sideways" robot and it worked out fine. There's nothing in the rules that makes it illegal as long as your robot fits the dimensions. The only problem you might right run into is turning, which becomes harder with the wider base.
Good luck!
-David
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 07-01-2008, 17:36
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Your robot can be either long or wide, as long as it can fit within a box 38" X 28" X 60"
Unread 07-01-2008, 17:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
we did it last year to have a bigger ramp, worked great
Good luck!
-David
Actually it's easier to turn with the wider wheelbase.
Unread 07-01-2008, 17:53
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
You can legally build a wide robot, but you'll have to think about what that will do to your robots stability. A wide robot is more likely to tip forwards or backwards than a long robot, so if you're holding a ten pound ball in the front, and get hit from the back you could have a problem.
Unread 08-01-2008, 00:37
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
yeah cuz the front and rear axles are so close together its smooth as margerine
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 08-01-2008, 00:41
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
but you have to remember that when lining up the robots for hybrid mode the rules state that you have to line up with the short side against the wall, so you would have to turn before driving, it would also make it harder to pass any robots as you would be wider.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 08-01-2008, 01:33
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
I'm missing this one somewhere. What rule says this? That could put a serious dent in many potential designs.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 08-01-2008, 01:37
mwibbels's Avatar
mwibbels mwibbels is offline
FRC #2122 (Team Tators)
Rookie Year: 2007
mwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond repute
Could you please site the rule that states the short side has to be against the wall in hybrid mode? <G15>, copied below seems to govern the starting position but doesn't seem to say which edge has to touch the wall.
<G15> ROBOT Starting Positions – Prior to the MATCH, the three alliance ROBOTS must be
placed entirely inside their HOME STRETCH, touching their Alliance Station Wall or the
angled fence in front of their local ROBOCOACH STATION, and not contacting any other
ROBOTS.
Mounting the ES17-12 sideways orientation SuperBK Electrical 10 21-01-2007 09:38
Sideways vs Forward Speed of Mercanum ggoldman Technical Discussion 1 20-01-2007 11:06
Can the Cameras be mounted Sideways? vicecityman666 Control System 1 29-01-2005 10:21
Can the Cameras be mounted Sideways? vicecityman666 Technical Discussion 1 29-01-2005 10:21
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
