Cylinder Weight
Greetings,
How much does a two inch bore, 8inch stroke bimba cylinder weigh? |
Re: 2 inch bore
Dunno. But I can tell you everything about what it looks like, because it will be very similar to McMaster part #6498K482. I was hoping that it would have shown the total weight of my order, and then I would have been able to help you out.
Re: Cylinder Weight
According to the Bimba Catalog, page 1.59, a 318-DXP cylinder weighs 2.82 pounds without any mounting parts.
In general when you have a question about a part, go to the manufacturer's web site and check their product page or catalog. Don |
Re: Cylinder Weight
I would agree with Don on this one because we have a 2" bore with a 24" storke that is at least 10lbs because it is real heavy.
Re: Cylinder Weight
Bimba Cylinder weights, from the 2003 pneumatics manual:
Approximate weight calculations for custom clinders, not including the rod clevis or pivot brackets: 3/4" Bore 0.21 lbs. + 0.03 lbs. per inch of stroke 1/2" Bore 0.73 lbs. + 0.08 lbs. per inch of stroke 2" Bore 1.62 lbs. + 0.15 lbs. per inch of stroke So 1.62+0.15*8 =2.82, sounds like same as the catalog. |
Re: 2 inch bore
Please tell me you aren't planning on putting that on your robot.
Re: 2 inch bore
Nope, I just looked it up for the guy. I was trying to see if McMaster would tell me the total weight of my order if I tried to add it to my shopping cart, but I couldn't figure that out, so I just posted the drawing instead.
| Weight? Estmate weight? | Arkorobotics | General Forum | 21 | 29-01-2007 17:34 |
| Wait...weight...weight!!!! | Greg Perkins | General Forum | 3 | 22-02-2006 07:42 |
| Cylinder weights | Captain Rich | Pneumatics | 3 | 30-03-2005 16:08 |
| Drawing on a cylinder | yamo18 | Inventor | 2 | 22-01-2004 22:23 |
| Rodless Cylinder | Clark Gilbert | Pneumatics | 10 | 01-11-2002 22:05 |
