Go to Post FIRST is NOT just about robotics. It is about the growth of leaders - of Gracious Professionals... - MysterE [more]
Unread 08-01-2008, 01:35
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Crab Drive HELP!!***
If you do decide to undertake a swerve/crab design make sure to spend a little extra time in the design process to build in a back up plan; Make you can switch the crab/swerve into just a normal 4WD in case it doesn't work out. This way you at least have a driving base in case of failure and won't be stuck with a completely disappointing season.
I'd say go for it if you have you have a reasonable amount of resources; you miss 100% of the shots you don't take.
Unread 08-01-2008, 19:27
CarpeNoctem's Avatar
CarpeNoctem CarpeNoctem is offline
Ranger
FRC #1057 (Blue Knights)
Team Role: Scout
CarpeNoctem is an unknown quantity at this point
Thumbs up Re: Crab Drive HELP!!***
My team had a crab drive system last year. It worked great and for the game this year it should be good for going around... you dont even have to turn.
But it probably would not be good for hurdling.. Its best use could most likely come from herding the ball around with it
When designing something completely fool-proof, we often underestimate the ingenuity of complete fools!
-Douglas Adams
Unread 08-01-2008, 14:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
GGCO,
Although crab drive is a great tool we don't use it all the time. It will only be incorporated into the robot design after careful consideration and playing the game. Don't make the decision at this point, play the game using chairs or tricycles or whatever and see if it is needed. If the team decides to use it then be advised that crab requires some strong mechanical attachments for both the top and botom, special handling to determine how assemblies are attached for steering, how to build a module so that both the wheel and the motor you use will fit into the space you require for turning the module and realize that crab by design puts the wheels closer to the center of the robot which compromises stability. After all of that is overcome, your drivers still need plenty of practice.
A so-so robot with lot's of practice will beat out a superior robot with no practice, every time.
As a personal request, can you include your first name in your profile? It makes it easier to respond. Thanks.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-01-2008, 15:04
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Ok, thanks all for replying! I am doing research and I am starting to see that a well designed robot/crab drive is not going to happen. I'll try to convince the rest of the team. THANKS!
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
HELP?!? with Omnidirectional/Crab Drive KMAC42 Technical Discussion 8 09-01-2007 21:34
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
