| View Poll Results: Average Lap Distance (ft) | |||
| 70 - 79 |
2 | 5.56% |
| 80 - 89 |
4 | 11.11% |
| 90 - 99 |
2 | 5.56% |
| 100 - 109 |
16 | 44.44% |
| 110 - 119 |
6 | 16.67% |
| 120 - 129 |
3 | 8.33% |
| 130 - 140 |
3 | 8.33% |
| Voters: 36. You may not vote on this poll | |||
We did a number of paper simulations of the average lap distance - laps with very little interference by the other robots, laps where the robot would need to weave around other robots - in an attempt to see what the average distance the robot would need to drive to score a lap. I would love to know what the CD community thinks the average distance per lap would be. Thanks!
Re: Average Lap Distance
So far, and it looks like the CD community is fairly consistant in its answers - the average lap distance is 100 - 110 feet. If so, and assuming with acceleration and deceleration - weaving through the crowds - turning, etc ... how many laps can you do in the 2 minute teleoperated period? We figured, using last year's robot, that we could do 10 ft/sec in the straight-aways, or 11 seconds with the calculated distance of the lap - BUT, with the other obstacles and turns, we figured a best guess of 16 seconds per lap, or about 8 laps per match.
How many laps do you think you could do during a match? |
I also ran some calculations with this yesterday.
Using the maximum robot size (with bumpers) of ~44" x 34". Using a CAD calculated elipse with a 870.5" (~72.54') total length shortest travel distance per lap with the best line. Using your given 10 ft/second robot speed... The most we can squeeze out of this field in a perfect situation with the maximum sized robot with absolutely no traffic would be: 20 laps in 1:45 (not counting time in Hybrid mode in able to get to "the perfect path") Good luck with any team who can accomplish this! I'm guessing a best lap count of about 10-15 will be very rare, and 5-10 will be the norm. Smaller robots will have a slight advantage as they will be able to manuver around robots & the track a lot quicker, and I see rookies hopefully realizing this and taking advantage of this if they don't want to build an arm for Ball manipulation. |
Just curious. -dave |
Hahaha! Oops..
As soon as I saw your post Dave I figured there was a reason you asked that. The explanation is that I was having flashbacks of 2 minute TOTAL time matches from yesteryear, and did my very quick calculations based on that brain hiccup and forgot the Teleoperated period time this year was 2:00 with 15 seconds of Hybrid.. Ok.. so with that said... I'll show my work this time. lol 870.5" long path @ 120" in/sec = ~7.25 second lap time. 120 second match (Teleoperated) / ~7.25 seconds a lap = ~16.5 laps After 15 seconds of Hybrid time, I would say a perfect line robot at maximum configuration could make in the Teleoperated mode of 2 minutes could make a total of ~16.5 laps. Aye... my math was way off in that first attempt I guess as well. 20 laps was a very generous overestimate I guess. I'll keep my prediction the same though with my original quote: Quote:
I computed a version of the 'fastest possible lap' yesterday, and found that a lap with semicircles at each end and lines for the straights has length:
2(pi*r + 27 - 2r). and that your best possible time per lap given radius r and friction coefficient u was: ttotal(u,r) = 2*pi*r / sqrt(9.8ur) + 4*sqrt( [27-r]/[4.8u] ) Note that there are many assumptions I made in order to get 'ideal' lap -Robots are points -Robots are powerful enough that their acceleration is friction-limited I think if you steered a 13ft radius corner at each end, thus carrying maximum speed out of each corner, a 5-6 second lap might be possible with a robot that dispenses with all other goals except speed. The best possible time for a friction-limited lap with u = 1.3 that does a 13ft corner at each end is 4.1 seconds. You can go much faster if you do a tight corner, but that's only because we're dealing with 1.3g acceleration along the straight. Last edited by Bongle : 08-01-2008 at 15:11. |
| Lap counted when lap indicator crosses line? | Madison | Technical Discussion | 6 | 08-01-2008 09:15 |
| pic: IR Lap Counter on the Manchester Kickoff Field | ahecht | Extra Discussion | 13 | 06-01-2008 21:38 |
| average score | tseres | General Forum | 15 | 18-08-2007 14:36 |
| Average Circles | shyra1353 | Math and Science | 9 | 26-07-2004 23:13 |
| WIN a Lap Top Computer! | archiver | 2000 | 0 | 24-06-2002 00:23 |
