Go to Post Own your words. - Joe Johnson [more]
Unread 08-01-2008, 01:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Exclamation Will your robot fit in the box?
It's three days into the 2008 season, and it's very likely that most teams are still deciding what to build. That means that it's a very good time to remind everyone about the fact that each robot will be placed inside of a sizing box, as part of the inspection at every event. (See <R11> and <R108>.)
Your robot must fit in the box.
Your robot may not cross the boundaries of the box, even by 1/16 of an inch. Even zip-ties, bolt heads and decorations count toward this restriction!
Your robot may not push on the panels of the box, or use it for support (except, obviously, the floor). Many robots violate this rule every year, and many inspections are failed because of it.
It's a fact of the competition that robot frames sometimes bend, or parallelogram. This can cause the bounding box of your robot to grow, potentially in excess of the size limit. Design your frame so this doesn't happen, perhaps by gusseting the corners, and using the bumpers as structural elements.
Remember, the sizing boxes measure every dimension at once, while a tape measure only measures lengths, not angles (which aren't always 90°). Plan ahead now. If there's no functional difference between 37 in and 38 in, why not leave yourself the extra space? The same goes for the other dimensions.
Don't be the team that ties up an inspector and a sizing box for 30 minutes, trying bravely to slide their robot in "just right". Even worse, don't be the team that whips out the hacksaw at the competition, because they didn't plan ahead.
P.S. Remember to weigh your robot well before the ship date. A regular bathroom scale usually works for this purpose. You don't want to be 30 lbs overweight on Thursday evening, 15 minutes before the pits close. (This really happened, but I conveniently forget which team was responsible.)
Unread 08-01-2008, 09:29
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Will your robot fit in the box?
The other box you have to fit into is your shipping crate. Not as much an issue as last year when you could have a 72" robot. But you still have to fit 60" of robot into a 70" (outside dimension) crate, with forklift skids.
(since 2004)
Unread 08-01-2008, 09:59
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
Team Role: Mechanical
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Mmmmm. Sizing box. It's so true what's been said about the unforgiving box. I will (sadly) say that we had to (slightly) modify the robot thanks to the sizing box. But teams, I can tell you now! While SOMETIMES an inspector may be nice enough to let a ziptie head that pokes out 1/16th of an inch over the 38 inch limit slide, don't let it happen. Play it safe, and leave a 1/2" safety zone on all sides of the robot to account for any parts that stick out.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 09-01-2008, 13:51
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
You could do what we do -- Max dimensions are 36" x 26". That's an extra 2in for each dimension. For bolt heads, zip ties and so forth. Worked well last year, too. Even when our frame was warped. And we never needed to use a hacksaw.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 09-01-2008, 15:18
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I've always allowed 1 inch off of each dimension. It's come in handy quite often, for when you suddenly decide you have to bolt some new componend onto the outside of the robot.
Another recommendation: if you're building an arm or any kind of mechanism that folds up, make sure you have enough clearance for the pieces to fold into starting position. I misjudged one section on last year's tube gripper (a pneumatic fitting!), and suffered in every inspection because of it. I couldn't make any modifications without destroying other parts, so we were one of those teams trying to get the robot to fit "just right". It's no fun, trust me. 2006, with our 27"x37"x59" box, was much less stressful, by far.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
WMR,what will your robot do? Jim Schaddelee Regional Competitions 0 20-03-2007 11:21
Which wheels will you use for your robot this year? GO Groves 1213 Technical Discussion 44 03-02-2007 12:36
Help! What kind of belt will fit on Denso Window Motor tstanis Motors 2 16-02-2006 14:52
How many will fit? Joe J. General Forum 1 15-01-2004 15:17
How fast will your robot be? Anton Abaya General Forum 18 20-01-2002 22:26
