Go to Post FIRST is the most glorious test of the mind. Anyone can run a marathon or get a slam-dunk. It takes guts to admit you are a nerd that enjoys six weeks off non-stop stress, and actually thrives on it. - kws4000 [more]
Unread 08-01-2008, 06:46
AmitCarmeli AmitCarmeli is offline
FRC #1943
AmitCarmeli is an unknown quantity at this point
OI Operations
Our team suggested that we should use in the OI Console different methods of control, such as remote controls (used originally for toy-engined cars or planes) or wheel-like joysticks.
What is your opinion about these suggestions? Can they function well?
Thanks in advanced, Team #1943.
Unread 08-01-2008, 08:39
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Re: OI Operations
You MUST use the provided OI (operator Interface) and RC (Robot Controller) boxes that you get in the kit or parts.... But if you really like using model car transmiters, you can adapt these to work with the OI.
You will still need a base to hold the actual OI computer, but you can wire a car controller (transmitter box) to the same inputs that you would normally plug the joysticks into.
You'd need to totally disable the original transmiter part.
Then, you'd need to get access to the actual joystick potentiometers inside the car controller. Maybe you can find one of those "Trainer" controlers that normally plug into the main transmitter. You then need to wire the potentiometers in the car controller to the inputs on the OI computer.
The potentiometers also need to match the specs of the OI, but it CAN be done if you have somone on the team that understands basic electronics.
Download the user manual for the OI computer from the ifirobotics.com site.
Phil
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Fast and Slow Operations Venkatesh Programming 2 15-01-2004 01:45
