Go to Post You won't find this in a manual anywhere but you will need COUGH DROPS!! If you haven't started losing your voice by Friday afternoon, you aren't getting the full experience. - wendymom [more]
Unread 08-01-2008, 12:28
MNov's Avatar
MNov MNov is offline
Giant deceptive face
AKA: Matan Nov
FRC #2230 (Zacharia's Angels)
MNov is an unknown quantity at this point
how to assemble the solenoids
My team built the pneumatic system, but the we're not sure how to assemble included solenoids, we're getting leaks and it's fairly frustrating.
Thanks.
Unread 08-01-2008, 13:45
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Re: how to assemble the solenoids
This is from memory, but you should have the following parts:
1) The thin solenoid part with the electrical connections
2) The metal manifold block
3) A thin gasket that goes between the 2. The pneumatics manual says "There are 2 gaskets included. Use the one with holes for the mounting screws."
4) 2 very long narrow screws
If you look at the gasket, I think there is a smooth side and a side that has a little raised ridge going around it. Look at the manifold and the solenoid; one of them has a groove for that ridge. Use some thin oil (WD40 works fine) and rub both faces of the gasket, making sure there is no dust or dirt on it. Put the 2 screws through the through holes in the solenoid and use them to align the gasket. Put the screws in to the tapped holes in the manifold and turn a couple threads to engage. Push the manifold and solenoid together, making sure the gasket doesn't crimp, then tighten the 2 screws the rest of the way.
If you have big leaks, as if the valve is not seating (air pouring out the exhaust ports), read through one of the threads in CD concerning solenoid wiring to make sure it is being actuated fully one way or the other. I've never had that problem but lots of teams have.
Close enough to taste it, too far to reach it
Unread 09-01-2008, 00:02
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
Read the Pneumatic Manual and Spike Manual Very help resources
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Is there a neutral with the solenoids given? Transformers Pneumatics 3 18-02-2007 01:48
Help How do i assemble the green target light?? jesusescobar Electrical 2 26-01-2007 17:32
How fast does the Solenoids turn on and off? Generalx5 Robotics Education and Curriculum 2 26-01-2007 01:09
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
