Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 08-01-2008, 16:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Gyroscope saturation?
We are planning on using the gyro angle to offset our cartesian coordinate plane so that when the operator presses the joystick away from himself, the robot always moves away from the operator regardless of robot orientation.
However, this years 80 degrees per second gyro has me a bit worried. It's tough to do by feel, but it sure seems like our robot can pull a 90 degree turn in less than 1 second by rotating.
Has anyone else had to deal with this, and does anyone think the robots can spin fast enough to saturate the gyro?
I considered purchasing last year's gyro but I can't find anywhere to do so.
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope ADXRS300 of Analog Devices rebekka Technical Discussion 2 07-12-2006 12:36
Stick Saturation Ralph Lambert Technical Discussion 7 20-01-2003 09:24
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
