Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 08-01-2008, 16:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Gyroscope saturation?
We are planning on using the gyro angle to offset our cartesian coordinate plane so that when the operator presses the joystick away from himself, the robot always moves away from the operator regardless of robot orientation.
However, this years 80 degrees per second gyro has me a bit worried. It's tough to do by feel, but it sure seems like our robot can pull a 90 degree turn in less than 1 second by rotating.
Has anyone else had to deal with this, and does anyone think the robots can spin fast enough to saturate the gyro?
I considered purchasing last year's gyro but I can't find anywhere to do so.
Unread 08-01-2008, 16:20
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Gyroscope saturation?
Yes, it's possible. Two potential solutions come to mind: 1) write some code that will monitor and record the peak values from the gyro. If you find that you have a problem, you can implement a control loop that will minimize the chance that the gyro will saturate. 2) Purchase another gyro like the ADXRS150 or the ADXRS300.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 09-01-2008, 08:51
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
We've had relatively good luck using 300 deg/s gyros. It's not fool-proof, however, since you'd be surprised the sorts of short-duration high-turn rate impulses you get from robot collisions. Expect it to still drift, especially in a game like this year's.
Unread 09-01-2008, 10:37
ubergeek5075's Avatar
ubergeek5075 ubergeek5075 is offline
FRC #0910 (Foley Freeze)
ubergeek5075 is an unknown quantity at this point
Last year for our dynamic braking system, we wanted a feedback loop from not only the optical encoders on the wheels, but also the gyros. However, I have experienced the same problems with saturation during collisions, and even when our robot turned fast enough.
I remember something from last year when i was researching the gyro from the KOP, that it was 150dps. Even with that we still had that saturation problem.
I agree with the solution of lower resolution gyros, but with the budget of a small team, it may take some convincing.
Also, what resolution on the controller end were you getting? How many values / dps rotation ?
Unread 09-01-2008, 11:11
Tom Line's Avatar
Rookie Year: 1999
Uber, we haven't implemented a testbed for this year yet, so I don't have any data. This was all hypothetical, because I was pretty sure you can saturate the 80 dps gyro pretty easily. I'll go with the 300.
Can collisions really saturate this gyro? How far off would that knock the reading? It seems to me most collisions don't spin robots at high rates.
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You could also ask your team the question of whether or not the robot should turn 90 degrees in less than a second for this game. Aside from sudden impacts that turn you, I doubt you'll ever have the need to experience a quick turn on a holonomic robot -- you could instead simply side-step an obstacle.
GitHub
Unread 09-01-2008, 12:29
Yes, collisions can cause saturation of the gyros, even if they result in turning the robot slowly. It's all physics, the collision results in an extremely high, however very short turn rates. Graphically speaking, the turn rate spikes, then drops down when your turn rate is constant. This results in some very odd data sometimes, depending on how long that spike lasts, and if you pick it up or not.
Unread 09-01-2008, 12:51
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
We've experimented with the 75, 80 and 150 deg/sec yaw rate sensors, in the past, and have always concluded that we needed to purchase a 300deg/sec sensor, to keep up with the turn-rate capability of out 'bots.
I used to get them right from AnalogDevices, but these past 2 years, they show that they (their evaluation boards) won't be in stock until April
Anyway, let me throw this out for consideration. Can the yaw rate sensor in the K.O.P be "over-clocked" (for lack of a better word) - to measure a wider range? I'd be willing to experiment with giving up some sensitivity, to get 300 deg/sec for the K.O.P sensor.
Eric
Don't PANIC!
S. P. A. M.
Unread 09-01-2008, 13:21
Tom Line's Avatar
Rookie Year: 1999
I seem to remember that by placing a resistor across the leads you can modify the dps, but reduce other functions. Look up and thoroughly read the manuals for each sensor - I think I saw it there.
http://www.analog.com/UploadedFiles/...s/ADXRS150.pdf
I believe it's the portion talking about changing the scale.
Unread 10-01-2008, 14:37
kaszeta's Avatar
There are plenty of other places to get Analog Devices gyros nicely mounted on evaluation boards. I've bought some nice 300 deg/s ones from Sparkfun.com, for example.
Unread 10-01-2008, 15:27
FRC #0180 (SPAM)
yeah..sorry... I should have said that I used to get them for $20 cheaper direct from AnalogDevices. I think I paid $70 for the SparkFun board last year. I also looked at a lot of yaw rate controllers from r/c aircraft catalogs. But they are controllers, not just sensors.
Anyone else take a look at what the r/c world has to offer? ...just curious
Eric
Don't PANIC!
S. P. A. M.
Unread 10-01-2008, 16:35
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
My team has always been a little bit scared of doing this because of the gyroscope values drifting. Would one of these (300 dps) gyroscopes allow you to track your orientation over a 2 minute period without introducing too much error?
- Toby
Unread 10-01-2008, 18:55
kaszeta's Avatar
Team 95 has used gyros for years, and aside from the above caveat that you can pick up errors from collisions, the system has worked very well for us.
Unread 08-01-2008, 16:23
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
I believe we have the same gyro as last year. If I am correct, it was also an 80 deg/sec gyro.
Try looking on SparkFun for a gyro. About $70 should get you a 150 or 300 deg/sec gyro.
Dang it Kevin, you beat me to it.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
  #15   Spotlight this post!
Unread 08-01-2008, 16:48
Tom Line's Avatar
Rookie Year: 1999
Bilbo, read this year's sensor manual. We have a new gyro. Last year's was 150 dps - so I wasn't terribly worried about saturating it with quick turns.
Thanks guys. I think I'll do both the code and purchase a higher dps one just to be sure. Better safe than sorry when it comes to the drivetrain.
Kevin, I'll admit that most of the words they're using on the specs page are foreign to me (mechanical engineer doing controls, go figure). Will the ADXRS300 simply "drop" in place of the KOP gyro using your same code?
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope ADXRS300 of Analog Devices rebekka Technical Discussion 2 07-12-2006 12:36
Stick Saturation Ralph Lambert Technical Discussion 7 20-01-2003 09:24
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
