Go to Post ...instead of question marks swirling my mind I got triangles, circles and squares... - Dorienne [more]
Unread 08-01-2008, 16:31
Ryank's Avatar
Ryank Ryank is offline
FRC #2523
Team Role: Student
Ryank is an unknown quantity at this point
Question RC will not communicate with OI
I admit we are a rookie team, so this is a probably a stupid mistake. That said, we have just assembled our kit-bot (a base robot with two victors with which to test things out and get used to wiring the electrical system, etc.) and everything works great. Battery blinks green, program function works, radio modem is solid orange, RC hardware blinks green, and RC mode is off. When putting in the modem (yes, into the radio port) and hooking up the OI with the transmitter, the trasmitter says transmitting but the reciever or modem on the robot just says "ready" and periodically blinks to receiving. The OI also says no data/radio. We have downloaded and installed the ifi_frc_beta_3[3] code to the robot controller and from what we can see it wrote (programm was oragne then finished and is now green). Any help? We just want to get this thing to a point where it can be driven with a joystick.
Unread 08-01-2008, 16:35
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: RC will not communicate with OI
I'm not sure if this is required the first time you set it up, but I know it is to change channels, so I'd assume it would be for this too. In the kit you recieved a red tether cable. Plug this into the slots that say tether on both the OI and RC. Then hit robot reset. Unplug, and have fun with the radios. Also, it's probably worth it to set your team number into the dipswitches on the OI, as you'll need to do that before the competition.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 08-01-2008, 16:36
caraddicted101 caraddicted101 is offline
Rookie Year: 2000
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
I would tether the robot to the OI and reset everything, turn it all off, then on again while still tethered. Then unplug the tether that that might solve the problem. I have had this problem many times before that this seemed to solve it most of the time.
-Hope this helps.
Unread 08-01-2008, 17:00
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
The other posts pretty much have this covered.
The first time you set up you need to have the OI tethered to the RI.
It allows the proper exchange of information. Actually just follow the directions in the Innovation FIRST documentation. On page 13 of the Operator Interface instructions it explains that you must tether the OI to the RI for the RI to get the team number. If you don't the RI cannot recognize the signal that it receives from the OI on the radio. You set your team number (in binary) on your OI first and then tether it up... it will then take this info and store it on the EEPROM in the OI. If you ever want to change the Team Number you just re-tether it up and it will take the new number.
One thing to remember...if you ever let any other team tether their OI to your robot you will HAVE to retether your OI in order to reestablish the proper ID number.
good luck!!!
I think everyone gets around to asking this question at some time.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Robot controller will not program teh_r4v3 Programming 2 25-01-2007 22:38
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
You animation will NOT be judged... dlavery 3D Animation and Competition 19 07-03-2006 18:05
FRC Problems, will not work nevrgonastopme0 Programming 4 04-02-2004 21:01
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
