Go to Post The Lord of the Bots.... - Bob Steele [more]
View Poll Results: How much does your frame weigh?
0-5 lbs 2 9.52%
5-10 lbs 5 23.81%
10-15 lbs 8 38.10%
15-20 lbs 2 9.52%
20+ lbs 4 19.05%
Voters: 21. You may not vote on this poll
Unread 08-01-2008, 19:26
RTTComanche17's Avatar
RTTComanche17 RTTComanche17 is offline
12ga Browning
FRC #1662 (Raptor Force Engineering)
RTTComanche17 is on a distinguished road
What is your frame weigh?
I was just curious to see how much material other teams are putting into their frame. Are you making it big and strong - to take a beating from falling trackballs and 150 lb robots flying around the field in excess of 15 fps, or small and light - to be nimble and save weight for your manipulator? i'm just looking for the frame. no motors or wheels just the bare metal frame.
What's Your Motivation?
Unread 08-01-2008, 19:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: What is your frame weigh?
10.75 lbs. with all hardware and bearings.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 08-01-2008, 20:41
Billfred's Avatar
Billfred Billfred is offline
IFI says the kit frame runs 13.4 pounds. I believe we'll have means to remove a pound or two from it, so probably 11.something. After the beating we put last year's frame through, I'm not worried about the durability in the slightest.
Unread 08-01-2008, 22:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Frame? huh...we still haven't figured out what type of drivetrain we'll have, so the frame could weigh from about 10 lbs to about 20, with the rough plans we have so far.
Car type drive and steering would be lightest, then tank style, and mecanum would be heaviest.
Unread 08-01-2008, 22:24
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
We're in the same situation here. We are actually thinking about the game & strategy & optimized designs before actually just going ahead and building something.
By the middle of week 2 we should be cutting parts, and by end of week 2 we should have at least a rolling chassis on the ground... (or flying around, or hovering... whatever kind of design we decide to go with to make the bot move around).
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 08-01-2008, 22:28
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
What constitutes a frame? Are the wheels included? Trans ? Motors? Shafts? Bearings? Or do you want just the metal with no drive components?
Unread 08-01-2008, 22:43
12ga Browning
just the bare frame. nothing else, just the metal.
Unread 09-01-2008, 10:45
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We haven't got any actual metal yet, but our calculated weight is around 15 pounds if we don't go with any weight reduction. I'll probably cheesehole a few pieces that I feel don't need to be that strong. Our complete drivetrain should be around 50 with motors, wheels, electronics, bolts, etc. Maybe less.
We're concentrating more on having a "heavy" chassis this year. Last year we took too much material out and it wound up bending in a few spots, could of been avoided if we had bumpers though.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-01-2008, 11:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Our prototype frame was 6.5 lbs, but that was with nothing welded to it for manipulator mounts and a big square gap in the front. Battery mounts and transmission mounts are welded to it as well, so those are included. We used 1" square alum 6061 extrusions with a 1/16" wall.
We're in CAD right now with the new frame and the mounts since we want to weld as much to the robot frame as possible, and it looks like we'll squeak by with about 9 or 11 lbs depending upon which design we go with. After being in the oven for a while since we powder coat it, it should be nice and strong, and beam with purple.
GitHub
Why didn't your team use the Kitbot frame in 2006? Billfred Kit & Additional Hardware 33 31-05-2006 00:00
Halfway through build: How much does your robot weigh? Elgin Clock General Forum 26 26-02-2006 21:29
pic: How heavy is your frame? rees2001 Robot Showcase 10 18-02-2005 22:38
What is your shipping crate made out of, and what does it weigh? Elgin Clock Technical Discussion 9 17-07-2004 20:02
How much does your robot weigh? Carl Owenby Technical Discussion 21 14-02-2003 13:41
