Go to Post I think it's important to keep FIRST's most important award as the top point getter [in Fantasy FIRST]. It's help reinforce that the Chairman's award, Engineering Inspiration and Woodie Flowers award are actually important and FIRST is about more than just the robots. - Koko Ed [more]
Unread 08-01-2008, 19:41
edBringas edBringas is offline
FRC #0743
edBringas is an unknown quantity at this point
what Chain size and tensioner to use for the drivetrain
Hi,
We are trying to decide our drivetrain this year, the question came up when discussing the chain size. I'm of the belief that the standard #35 is fine but others think a thinner chain might be better. Any thoughts?
Also in the past we created our own tensioners with store bought pvc but this year we want to buy a manfactured tensioner to prevent the chain to fall off. Does anyone have a good online source?
Thanks
-Ed
Unread 08-01-2008, 19:55
davidhoughton davidhoughton is offline
FRC #0753 (high desert droids)
Team Role: Mechanical
Rookie Year: 2007
davidhoughton is an unknown quantity at this point
Re: what Chain size and tensioner to use for the drivetrain
personally i would go with the larger burlier chain due to strength but if you are needing to save weight it would probably be better to go with the smaller chain
as far as a tensioner gos im not sure
hope i have been of some help
Unread 08-01-2008, 20:00
CraigHickman
Posts: n/a
We use #25 for everything. As long as you run it/tension it properly, there is no conceivable way you could break it. Please note I'm not saying it's invincible, I'm saying when done correctly, it is more than strong enough.
As for tensioners, that depends on your drivetrain setup. Some teams buy idler sprockets from McMaster, or some equivalent, and then put it on a U bolt so it's adjustable. I personally prefer to go with live Axles, and pull bearing blocks. But that requires more machining and materials.
Good luck! Post some pictures once you finish it, so we can see!
Unread 08-01-2008, 20:07
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
This depends on your application. Teams have used either #25 or #35 with success (and rarely, other sizes as well), but there have been some ugly instances where the wrong chain for the job was used.
Estimate the loads on the chain by consulting a design manual like this (look for ANSI roller chain, e.g. RS25 or RS35) to get an idea of the power that the chain will accept, at a given speed. (That manual lists the allowable horsepower for each chain type, for a given sprocket size, at some speed, assuming the full working load is applied. Note that the working load is significantly less than the breaking load, because the manufacturer has selected a factor of safety.) Then have a look at the Tsubaki troubleshooting guide to avoid the situations that can damage chain or reduce performance.
As a general principle, the tensile load in a chain is inversely proportional to the sprocket diameter. Big sprockets are safer than small ones, if the chain is at risk of breaking.
Unread 08-01-2008, 20:39
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
We are going with something totally different this year. Bike chain with custom made sprockets. Lighter and stronger like #35 chain but with the #25 chain weight. The pitch on the sprockets are different from the standard 25 and 35 chain. We made our own.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 08-01-2008, 20:52
RTTComanche17's Avatar
RTTComanche17 RTTComanche17 is offline
12ga Browning
FRC #1662 (Raptor Force Engineering)
RTTComanche17 is on a distinguished road
our team has only used 35 chain. we have absolutely put it to the test too, and it has never broken. our bot in 2006 outpushed every ither bot we went up against, even the ones with outback style track designs. we bent our frame causing the chain to rub the inner frame rail, the wheel, be out of alignment, and have excess slack. it never failed. we had to replace our wheel cuz the chain started to eat throuth the aluminum side plate. 35 chain is cheap insurance. use it!
What's Your Motivation?
Unread 08-01-2008, 23:31
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
25-pitch chain will work fine for drive-train applications if you can manage the manufacturing tolerance required, and save you a fair amount of weight over 35-pitch. Team 190 has always used 25-pitch roller chain, and Team 228 will be going with 25-pitch this year.
As for tensioning roller chain, Team 228 always uses an extremely simple method of using HDPE bar stock with an off-center hole. As you rotate the HDPE around the center hole, the diameter changes and works perfectly for adding tension to roller chain. Here's a photo of three applications of these simple chain tensioners from our 2007 robot:
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 09-01-2008, 13:58
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
#35 chain, and might I be the first to suggest sliding motor mounts? Leave some tolerances and mill out slots so that your motor mounts and bearingplate supports can slide back and forth -- then there's no use for tensioners, and you save some extra weight. It does take a bit more thought, though. 675 used sliding motors last year and we used tensioners the year before, and all I can say is we're not going back to tensioners.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 09-01-2008, 14:04
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
We'll be using #25 chain for our drive this year. We'll tension it by sliding the front and back wheels, center wheel is direct driven.
Unread 09-01-2008, 14:43
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I always use #35 for drivetrains. I've found that it's much more forgiving when dealing with misalignment. If you've got the skills and resources to keep your tolerances tight, your chain properly tensioned, and a relatively short chain, #25 can work just fine. For something as mission-critical as the drivetrain, though, I prefer the security of the bigger stuff.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 09-01-2008, 22:12
EduardoVemny EduardoVemny is offline
FRC #0743 (Technobots)
EduardoVemny is an unknown quantity at this point
Thanks for the info, Though my gut said #35 chain, my skill set has always been electrical/programming and thus wanted to make sure. To bad we don't have a mechanic/engineer to confirm what I thought this year.
As for the tensioner I think we are going with artdutra04 idea. Alas we do not have access to a mill and this might be the best route.
Thanks
Unread 09-01-2008, 23:15
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
I def agree. We started using HDPE two years ago and have never looked back. Its easy light simple and effective.
Unread 09-01-2008, 23:57
Darunada Darunada is offline
AKA: Lea Fairbanks
FRC #4598
Darunada is on a distinguished road
the chain doesn't eat the HDPE away?
The reason I ask is because the chain ate away a good half inch into our robot when some bolts rattled loose on a pneumatic tire, causing it to expand and push the sprocket (and thus, chain) into the frame.
Unread 10-01-2008, 00:02
DonRotolo's Avatar
Back to humble
FRC #0832
Read the highlighted phrase above again. #25 is fine, but only IF...
#35 is far more forgiving, but heavier.
  #15   Spotlight this post!
Unread 10-01-2008, 01:14
artdutra04's Avatar
Not any appreciable amount over the course of a competition season.
If you use softer or lower density plastics, the roller chain will start eating away the plastic rather quickly. But the High Density property of HDPE is great to act as a low-friction surface for the roller chain, without being eaten away.
On our previous robots, after four or five competitions, all we'd notice on our chain tensioners would be a two small grooves about 1/16" of an inch deep.
Art Dutra IV
世上无难事,只怕有心人.
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
What size breaker should I use for the RC? Excelsior Electrical 4 18-01-2006 07:34
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
