Go to Post This is what happens when a couple of whackos get an idea at 2 am. - Rich Kressly [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 08-01-2008, 20:31
jln646v jln646v is offline
AKA: Vincent Juliano
FRC #0514 (RPM)
jln646v is an unknown quantity at this point
Send a message via AIM to jln646v
Infrared Sensor Interface Problems
I am using the infrared sensor included with the kit of parts with the 2005 edubot. I have power going in the 1st and 3rd pin and have the 5th 6th and 7th pins going to the signal pin of 3 digital inputs using a pwm cable. The other one is not hooked up to anything.
When none of the buttons on the remote are pressed or a pin is not hooked up to the signal pin, the value is 1. When i only have 2 inputs hooked up, everything works correctly. The correct digital inputs go to 0.
When i have the 3rd one hooked up, when i activate one input the 1st and 3rd digtal inputs turn to 0. When i activate the 2nd, the 2nd and third pins go to 0. Both times only one light is flashing on the infrared sensor, so it looks like everything is working correctly there. Does anyone know what is causing this, i dont see any shorts or anything.
Interestinly enough, i dont know if this is related, if i have digital inputs one and two hooked up and take the 3rd pin and touch it to the ground, digital inputs go to 0.
Any help would be greatly appreciated.
PBASIC operator interface LED problems John Gutmann Programming 1 19-05-2005 10:39
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
Operator Interface Problems - Won't Boot Jamie_Richard Control System 1 14-02-2004 17:20
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
