Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 08-01-2008, 21:24
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Friction and Trackballs
I'm not sure if this is the right place to post this question, but here goes...
What have people found to be good for 'gripping' the trackball? Non-slip matting for drawers slides right off, and rubber wheels slip a bit, too. The tread from the InnovationFirst traction wheels grips ok, but not great...
Ideally, we'd like to pick up the ball and hold it rather firmly -- so does anyone have any suggestions as to materials that will 'stick' to the polycanvas cover?
Thanks!
Patrick
1551
"The Grapes of Wrath"
Patrick Freivald -- Mentor
Team 1551
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 08-01-2008, 21:29
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Re: Friction and Trackballs
actually we found non slip drawer covers to be very grippy, far more than the rubber from traction wheels. I'd recommend buying different brands and find the grippiest because ours is incredibly grippy (sorry i do not know the brand off the top of my head).
2005- Davis- Sacramento Regional Champions (w/245 and 1072)
2005- Silicon Valley Industrial Design Award Winner
2005- Archimedes Divison Champion (w/245 and 217)
2006- Silicon Valley Regional Champions (w/254 and 581)
2007- Silicon Valley Regional Finalists (w/488 and 852)
2007- Alliance captain of only alliance (w/488 and 852) ever to defeat 254 at SVR
Unread 08-01-2008, 22:43
Neil B's Avatar
Neil B Neil B is offline
GNΩZ
FRC #0830 (Rat Pack)
Neil B is an unknown quantity at this point
Send a message via AIM to Neil B
From what I know there are two kinds of non-slip matting: There's the more foam-like kind which is typically very sticky to almost everything relatively smooth. Then there's a more rubber-like kind that really only sticks to glass or smooth plastic but not much else.
In general I think softer gripping materials will provide you with more grip. Or you could just squeeze the trackball with lots of force; either one should work.
Unread 10-01-2008, 10:01
pfreivald's Avatar
We want to make a C-shaped 'claw' that has no moving parts except for rollers on the end that will 'suck in' and 'spit out' the trackballs -- so we need something nice and grippy on the rollers.
We've tried a variety of materials -- 3M Aluminum Oxide 320 grit circles actually grip pretty well, but I think they'd have to be replaced often, and might, just might, violate the rules because they are technically an 'abrasive'...
Of the four brands of non-slip matting at the local hardware store, none grip effectively.
Patrick
Team 1551
I write books, too!
Unread 10-01-2008, 10:56
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
http://www.handstands.com/retail/aut...sticky-pad.php
They're sold at Target.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 10-01-2008, 11:07
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Team Role: Coach
Rookie Year: 1996
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
So far we have found that the only thing that effectively sticks to the track balls is dirt and dust, and we have a very dusty work area. We may have a gray track ball by the end of build season.
RAZ
Unread 10-01-2008, 15:51
Darunada Darunada is offline
AKA: Lea Fairbanks
FRC #4598
Darunada is on a distinguished road
I had the idea of carpeting the other day... anyone have some samples to try? Probably not field-style carpeting, but more bedroom style stuff. I imagine it working good, but that's no substitute to a test
Unread 11-01-2008, 09:49
pfreivald's Avatar
Ok, we've found the ubermaterial... Red gasket rubber from the local hardware store acts like sharkskin gloves on a football -- it's *fantastic*, cheap, durable, and easy to replace.
Life = good.
Thanks for the ideas, all!
Team 1551
I write books, too!
Trackballs chaineezee General Forum 67 25-01-2008 11:10
Contact Area and its Relation to Friction? Qbranch Technical Discussion 51 17-01-2008 09:31
Bouncing TrackBalls GBilletdeaux930 Rules/Strategy 22 09-01-2008 22:17
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
