Go to Post "Building the technology of tomorrow - sometime late tonight!" - dlavery [more]
Unread 08-01-2008, 21:48
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
Pros & Cons of Carb/Swerve Drive Train.
Our team would like to go with this design but were not sure how to achieve this.Does anyone else have any other design and what are the pros and cons of a crab/ swerve drive train?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 08-01-2008, 22:08
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Re: Pros & Cons of Carb/Swerve Drive Train.
Woah, why do you need 6 wheels?
The big pro is the maneuverability. Cons: heavy, complex, drivetrain uses up lots of motors (well not too many with coaxial swerve), and it's unwise to try one for the first time under the time constraints of build.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 08-01-2008, 22:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You only need four, or even three (team 16 in 2006). The two in the middle are extra weight.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2008, 22:16
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
Our mentor thinks that 6 wheels is better but i personally think that the whole idea of a crab design is to complex.
Unread 08-01-2008, 22:18
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
In this case, you are probably right. 6 wheels is better than four wheels for skid steering, not crab drive. At this point, you should probably not try a crab.
Oh, and the biggest problem with your posted design is that those center wheels had better be omnis, otherwise you won't be able to go sideways (which is the main point of having a crab drive).
Past teams:
Unread 08-01-2008, 22:20
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I would agree, if you havent thought of how to build one before the build season, chances are slim that you will be able to finish it properly.
and I am also curious as to why you want to have 6 wheels. why not just the 4 steering wheels???
Unread 08-01-2008, 22:23
rachal's Avatar
multipurpose tool
AKA: Rachel
I mean, why do you have a diagram of a 6-wheeled-swerve? Swerve only needs 4.
So your mentor wants to do a normal 6 wheel, and your team wants a swerve/crab? I'm confused
Unread 08-01-2008, 22:30
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
the other way around, our team would like to go with a standard 6 wheel drive train with middle wheel lowered, but our mentor wants to go with a 6 wheeled swerve train for some reason,like the picture above
Unread 08-01-2008, 22:32
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
Good point.
The middle wheels are not omni wheels but andymark wheels. Our mentor says that the middle wheels are for traction.
Unread 08-01-2008, 22:35
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
There is no good reason to have a fifth and sixth wheel in a swerve. Unless, of course, he wants a Chariot style of drivetrain... (The robot on top has a crab drive with four wheels.)
6-wheel dropped center is pretty standard; it's hard to get in trouble with that.
Past teams:
Unread 08-01-2008, 22:36
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Take it from me 6-wheel crab is overkill and overly complex. I cannot think of any advantage of adding the 2 extra wheels.
Did your mentor really mean that they want 6 wheels with monster-truck steering? Even in that case, 4 wheels would work best.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 08-01-2008, 22:41
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
I dont know what he's thinking, but I'll talk to him and my team about it.
Our mentor is an autotech teacher
Unread 08-01-2008, 22:52
Neil B's Avatar
Neil B Neil B is offline
GNΩZ
FRC #0830 (Rat Pack)
Neil B is an unknown quantity at this point
Send a message via AIM to Neil B
Yeah, as almost everyone else said, 4 wheels is probably best. Crab drive is heavy as it is; no need for extra wheels and weight.
What I've heard is a major problem with crab drive isn't so much the construction (although that's a task in itself) but the programming. You have to have sensors to make sure that all the wheels are pointed in the correct direction at the same time. Then you have to have a program to make sense of the data those sensors are sending to RC. All in all it's a tough job that probably should be started before the build season.
6WD Pros and Cons ChuckDickerson General Forum 59 13-01-2008 02:20
Kitbot pros and cons Jaybee1405 Kit & Additional Hardware 16 06-01-2008 23:57
Two cameras: Pros and Cons cooknl Programming 1 12-01-2006 20:57
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Practicing after Ship - pros & cons Natchez General Forum 24 18-01-2005 23:06
