Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 08-01-2008, 22:25
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
Mistake? Wheel w/ bearings
Our team ordered 6 andy mark wheels with bearing in all wheels. We planned on going with a live axis to the middle wheels in a 6WD but when we tryed to mount the toughtbox and wheels, we found out that when the toughtbox output shaft is put into the bearing of the middle wheel the output shaft just spins and wheels doesnt rotate because of the wheel bearing. Is there a way to fix this?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 08-01-2008, 22:30
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: Mistake? Wheel w/ bearings
You could remove the wheel bearings and mount the wheel to this hub. The hub fits the gearbox output shaft.
Richard Wallace
since 2003
Unread 09-01-2008, 00:39
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
You would be better off attaching a sprocket to the wheel and running chain from the sprocket on the gearbox to the wheel that way.
Live axle means that the wheel is ATTACHED to the axle.
Dead axle means the wheel rotates on the axle.
In order to create a forward force, you must either attach the wheel to the axle or drive the wheel instead.
I also would not recommend direct driving and wheels with these gearboxes unless you are supporting the shaft on the other side. Adding sideloads increases breakdowns and decreases efficiency.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
07 Kit Wheel Bearings Dilemma sonofdad123 Kit & Additional Hardware 12 16-01-2007 23:03
Image Discuss: Team 57 - Rookie builder mistake CD47-Bot Robot Showcase 2 14-02-2003 09:15
$3500 ruling......big mistake JamesJones Rules/Strategy 42 13-01-2003 18:38
" biggest mistake.......most gratifying experience.......... archiver 2001 5 24-06-2002 03:27
Gracious Professionalism about a mistake rachakate Regional Competitions 13 28-03-2002 08:49
