Go to Post I always say find what works best for your team, for your given situation. Why should we rely on someone else to tell me what will work best for our situation? - JVN [more]
Unread 08-01-2008, 22:43
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
The physics behind trackball inflation
Okay, it starts with a simple question:
Does the trackball weight change when you inflate it?
My team had a fairly heated argument about this, and somehow I suspect we weren't the only ones. At any rate, to avoid further misunderstandings, let this post try to quash some of the debate about trackball weight vs. inflation:
  • An uninflated trackball consists of just the skin.
  • An inflated trackball consists of the skin plus a large quantity of air.
Since air does have mass, this increases the mass of the trackball.
  1. The density of air at sea level pressure and 20 degrees Celsius is approximately 1.2 kg per cubic meter.
  2. The trackball contains about 0.55 meters of air (radius = 20 in = 0.508 m, volume of sphere = 4/3 * pi * r^3 = 0.55).
  3. Mass = volume * density, so 0.55 cubic meters * 1.2 kg per cubic meter = 0.66 kg.
  4. On Earth, this translates to about 1.46 pounds of additional weight.
HOWEVER, the additional weight (downward force) of the air in the trackball is completely negated by the UPWARD BUOYANT FORCE of the atmosphere on the ball assuming that the trackball is inflated to the same pressure and temperature as the surrounding air.
On buoyant force: basically, the scale doesn't measure extra weight because when you put extra air inside the trackball, you're causing it to displace the same volume of air that would otherwise be weighing down on the scale anyway. The scale doesn't care if the air is inside the trackball or outside it.
THEREFORE, the only way inflating your trackball can cause it to weigh more is if the trackball actually contains more air mass-wise than the volume of air it displaced. For this to happen, the air in the trackball must be at a greater pressure than the outside air.
Pressure and amount of gas are directly proportional thanks to the ideal gas law (pV = nRT, where p is pressure and n is amount of gas), so if your trackball is inflated to twice atmospheric pressure, it will contain twice the amount of gas and thus twice the extra mass. Since you now have 2 masses of air, the weight is twice as much (about 3 lbs) whereas the upward buoyant force (based on the volume of air displaced) remains the same at about 1.5 lbs. Therefore the net added weight (downward force) would be about 1.5 lbs.
There's a pretty good walkthrough expressing these principles with a similar situation at this site:
http://rabi.phys.virginia.edu/105/2006/ps5s.html
So, the gist of this argument is that:
  • It's perfectly possible for an inflated trackball to weigh exactly the same as it did uninflated (if it's inflated to atmospheric pressure).
  • The above trackball still has a greater mass, meaning it would be slightly harder to accelerate.
  • It's also perfectly possible for a trackball to weigh more when inflated (if it's inflated to above atmospheric pressure).
  • All the same, it's unlikely that you could get your trackball to weigh 10 pounds if the skin only weighs 7 (that would require inflating it to 3x atmospheric pressure, or 45 PSI).
Okay. Sorry to wax a bit verbose, but I wanted to create a thorough explanation to help clear up ANY doubts about this issue, since there seem to be a fair number. Hope this helps people understand the science behind the problem. I tried to be as careful as possible, double-checking and citing my work, but if I've made any mistake please correct me. Thanks.
Unread 09-01-2008, 02:31
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Re: The physics behind trackball inflation
Sounds pretty good to me, I don't claim to be an ball pressure-weight expert, but I have do have a degree in physics and have taught physics for 14 years and would give you an A for your presentation of the situation. You could've have got an A+, but you missed the part about the difference in composition of the gas inside the ball and the surrounding air (the compressor may add a few dirty molecules). But seriously - you summed it up nicely!!
We weighed our ball, inflated to 40" in size, and it came out to about 7.2 lbs. After reading the manual, it said it will weigh 10 pounds. I thought our scale was off or needed to be calibrated, but I think your findings support our scale's reading.
Work Hard, Have Fun, Make a Difference!
Unread 09-01-2008, 02:56
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
well in theory with the added weight of the skin any air on the inside would be compressed past 1 atm (~14.7 psi) (PROOF: unplugging a partially inflated ball will still deflate signaling that the interior pressure was greater then the exterior.) so any inflation would add mass, but should be negligable till ball reaches maximum volume, dictated by the material's elastic constant.
(I always love myself a good debate )
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 09-01-2008, 07:59
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
The pressure cs. diameter function is probably highly non-linear once you reach the size of the nylon and start trying to expand that. All the same we whipped out a ball pump to hook up to the trackball after it was inflated and it read something less than 2 psi. Probably 1. So there will be some additional weight. I imagine the manufacturing variances will compound the weight fluctuations from air pressure with slightly thicker, heavier balls requiring even more air to inflate. Overall, though, I wouldn't expect for than +/- .25 lb variation out to 3 SDs
Unread 09-01-2008, 08:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The mass of the air inside the ball could make a difference in a design that "shoots" the ball....that's a significant added load....that I had not thought of!
thanks for the lesson!
Unread 09-01-2008, 08:43
Miniflash's Avatar
Miniflash Miniflash is offline
AKA: Gordon Wyant
FRC #2028 (Deep Impact)
Team Role: Human Player
Miniflash is on a distinguished road
i just fill it up ,weigh my self, then weigh myself while holding the ball and take the diffrence... easy math for us k.i.s.s people ... then to double chech take a string and take the circumfrence and divide by pi.... easy enough to the point of i have a 10lb 40 in diamater trackball
Unread 09-01-2008, 16:27
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
But you have to move the ball, too. For that you'll need to know the mass, as described above.
Trackball inflation Laaba 80 Rules/Strategy 15 13-01-2008 12:59
pic: Trackball vs. MiniFRC Trackball Jessica Boucher Extra Discussion 3 08-01-2008 03:08
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
'Behind the Scenes' - Team357.org Knippschild Website Design/Showcase 1 08-03-2007 18:55
Stuff Behind the glass SpaceOsc General Forum 19 03-03-2004 13:42
