Hybrid mode?
can someone fully explain hybrid mode to me, it's my first year and i have no idea
Re: Hybrid mode?
Hybrid mode is where your robot runs almost entirely in autonomous, but you can have a "Robocoach" who is a person with an IR Remote (Like one from a TV) who can send 4 top level commands to the Robot to control it (For example: Turn left, get ball, stop, etc...)
Re: Hybrid mode?
Used to be, the match just started in teleop mode (1992-2002). Then, the GDC introduced autonomous mode, where the robot is controlled by onboard sensors and programming only--no driver input (2003-2007). Now, they have changed auto mode to hybrid mode--the Robocoach (who takes the place of the Human Player) has a limited command set that he/she can send to the robot. The robot must still use only internal programming, but the Robocoach can tell it what to do in the programming. This can by via IR, sound, or light, or any other means that fits within the rules.
Re: Hybrid mode?
Some people on my team were misunderstanding it. Hybrid mode actually allows you to semi-fully control your robot with the right programming.
Example: Channel 1 = Drive Forward Channel 2 = Turn Left Channel 3 = Turn Right Channel 4 = Raise Arm, etc You can then program the robot to cancel the program by pressing the program's assigned button a second time. With this setup, you can completely control your robot in hybrid mode. You can press button 1 to drive forward, button 4 to raise arm, button 2 or 3 to turn left/right to align with a trackball, then knock one off for the 12 point bonus. You can also press button 1 a second time to stop, or button 2/3 to turn more or less left/right. I just wish it wasn't with IR and was with something a bit more reliable. I like this better than autonomous mode though. There's a slight bit of human interaction, no messing with timing, CMU cams, etc. |
Re: Hybrid mode?
The IR received has been provided to teams as an EXAMPLE technology. It is not a REQUIRED technology. There is nothing in the rules to prevent you from using other technologies to communicate your four commands to the robot during Hybrid Mode. If you have a preference for a different technology (that is within the rules, e.g. no lasers) then go ahead and use it! -dave |
Re: Hybrid mode?
That just opened up a whole new can of worms. I suddenly feel overwhelmed this year just from that one simple post. lol I guess that's because I don't have an "electrical background" per-say, but up until that point I was semi-confident of my robotics knowledge being involved with this program for what is my 8th year this year. With that said, I won't ask you specifically Dave even though you seem to have some inside knowledge on the issue, but more towards the CD community... What are some other forms of remote communication (AKA: Signaling device) we are allowed by the rules to use this year other than IR types? |
Re: Hybrid mode?
Basically what I meant by saying "just IR" is the fact that I've had bad experiences with it. It drops out frequently. We've all seen it, TV remotes.....
Re: Hybrid mode?
-dave . |
Re: Hybrid mode?
I was wondering for the commands, could they be like
press button 3 and the robot stops, moves an arm up, and opens a "claw" mechanism, then moves forward. so there are multiple actions on one button or is that illegal |
#10
Re: Hybrid mode?
You should make each channel do one task to make things easier, but if you technically have no more than 4 tasks done by the same channel, that appears to be legal. |
#11
Re: Hybrid mode?
Now, you could make a case both ways. Or you could ask Q&A if one "action" can be a series of actions triggered by one command sent by one button push or whatever you use. |
#12
umm... in hybrid mode the robot is controlled by the robocoach... so can the robocoach signal the robot to go clockwise in hybrid mode
#13
Re: Hybrid mode...
As long as the robocoach doesn't mind suffering the wrath of the alliance partners when the 10-point penalties start accumulating.
#14
Re: Hybrid mode?
So does anyone know what frequency of the remote we will be using? And what about the code for programming?
#15
Re: Hybrid mode?
Pick your own remote. Write your own code. Ask for help if you need it.
| Hybrid mode issue | Los Frijoles | General Forum | 2 | 07-01-2008 18:52 |
| Track balls off the overpass in Hybrid mode- who scores? | Japper | Rules/Strategy | 1 | 07-01-2008 11:24 |
| Has a hybrid won yet? | chaoticprout | General Forum | 46 | 27-04-2007 22:44 |
| pic: VEX hybrid | John Gutmann | Extra Discussion | 3 | 01-02-2007 12:08 |
| Safari Hybrid View Problems | Joe Matt | CD Forum Support | 4 | 09-12-2003 00:19 |
