Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 09-01-2008, 10:54
BaldGuy BaldGuy is offline
AKA: Harry
FRC #1518 (Palmyra-Macedon Raiders; previously known as Ulterior Motive)
BaldGuy is an unknown quantity at this point
Carrying the ball under the overpass but across the finish line
Does this action result in only 2 points (for the robot, 0 for the ball) since the ball was in contact with the robot?, according rule G10?
2007 FLR- Finalist (with 340 & 354)
2011 FLR Champions (with 217 & 2056)
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Carrying the ball under the overpass but across the finish line
That's what it sounds like to me!
Unread 09-01-2008, 12:11
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Sounds to me the ball CANNOT be carried to score. It must cross the line while its not in contact with a robot, unless its in contact with robots of both alliances. That second part is puzzling to me.
<G10>Each TRACKBALL that has CROSSED its own FINISH LINE while not in contact with a
ROBOT of the same ALLIANCE will earn 2 points. A TRACKBALL that has CROSSED its
own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn
2 points.
Brian K
Team 1225 Robotics Mentor
Unread 09-01-2008, 12:30
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
2 points.
Wow, that had me puzzled for a second too.
Kind of weird when you first read it.
If your robot (and your robot alone, or a combination of your robot and your alliance partner's robot together) is holding or (touching in any way) your own ball and you pass the finish line, then it does not count as scoring.
If you are holding your ball and while crossing the finish line the ball is touching your opposing alliance robot then it counts? Or to the extreme "why the heck on earth would this happen? type of scenario" if your opposing alliance's robot carries your ball over your finish line then it counts.
This is odd. So.. basically.. if I am understanding this correctly, if you're drafting a robot of the opossing alliance and holding a ball (say 2 feet in the air).. make sure that before you cross your finish line the ball in your posession touches your opposing alliance's robot as your cross your own finish line and it will count?? (As it will now be satisfying ".... A TRACKBALL that has CROSSED its own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn 2 points.")
What the heck?? That's interesting. I can see people pushing their opposing alliance robots through their own finish lines with the balls in between them and it counts as 2 points? Is this GP at all???
Hmmm... am I reading this right?
Thoughts?
I think this will go back to the definition of Crossing though.
CROSSING: The act of a TRCKBALL or ROBOT passing through the plane defined by a line (i.e.
LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or
ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise
direction, have completely passed through the plane.
What does projected vertically upward mean? I think with a robot it would mean in an upright and (assumably) driveable position, but how do you define "vertically upward" with a round ball???
OMG, I'm reading wayyyyy to deep into these things I think.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 09-01-2008, 13:41
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
There are two conditions under which a trackball may score 2 points in <G10>. One is if it crosses the line without being in contact with a robot from your alliance. The other is if it is simultaneously in contact with robots from both alliances. Either one scores the points. Your choice is to bop the ball across the line, or to convince your opponent to help you carry it across.
The "vertical projection" is the vertical plane that is defined by the line, not the robot or the trackball.
(since 2004)
Unread 09-01-2008, 13:47
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
So if you carry, push, shove, bounce an opponents trackball across their finish line you have just given them two points?
Has anyone found anything that says the trackball only counts as crossing (to reset for scoring, hurdling or crossing alliance finish line) a finish line if it is traveling in a counter-clockwise direction?
Unread 09-01-2008, 13:50
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Look 2 posts above yours.
(since 2004)
Unread 09-01-2008, 13:58
ALIBI's Avatar
FRC #0141
Team Role: Parent
OOPS, so sorry, I am still having trouble with these bifocals. It seems as though I can read and re-read and re-read the rules and definitions and still miss something.
Unread 09-01-2008, 14:11
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
This scenario was explicitly called out in the human simulation at Kickoff. One of the blue robots didn't unload the ball before crossing the finish line, and didn't get the points for the ball.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-01-2008, 14:20
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
It seems your best bet is to roll the ball across the line and than follow it across without touching it.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 09-01-2008, 14:23
Blue robot with a Blue Ball I'm guessing?
I wasn't really paying attention to the human demonstration on the screen in front of us. Too much other stuff going on during the live kickoff on top of the Camera boom being right in front of us blocking the screen half the time lead to me not watching something that was pre-recorded (And not done live, which the human player match was). lol
I'll go back and watch that though. Thanks for the tip Eric!
Unread 09-01-2008, 14:25
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Yep.
Past teams:
Unread 09-01-2008, 14:48
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Think about the following scenario -
Cute, friendly Redabot is approaching the Red Finish Line, "dribbling" a Red Trackball in front of it with the intent of pushing it across the Finish Line. Evil, nasty Blueabot is waiting just on the other side of the line. Redabot bumps the Trackball to knock it across the Finish Line for a score. But Blueabot moves to bounce the Trackball backwards and into contact with Redabot, to prevent the score. Redabot and Blueabot get into a pushing match with the Trackball in between them, which is straddling the Finish Line.
If Blueabot is the more powerful, it will push Redabot and the Trackball backwards and out of scoring position. It will also likely penetrate the plane of the Finish Line in the process, and take a 10 point penalty. If Redabot is the more powerful, then it will push the Trackball (and Blueabot) across the Finish Line. Due to this rule, the score will count. In either case, Blueabot will have failed. Moral of the story: don't do this.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 09-01-2008, 14:53
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
-dave
I'm impressed that the game designers are on top of things this much. This is one of those "----- if you do, ----- if you don't" situations for defense, set up by the rules. That explicit exception is pure genius.
Past teams:
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
How to get the ball over the overpass!? ar2 General Forum 63 11-01-2008 23:58
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
Quick clarification regarding crossing the finish line MNov Rules/Strategy 18 06-01-2008 18:06
Do the bins fit under the bar? Wayne C. General Forum 22 13-05-2003 16:40
