Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
View Poll Results: What is the main component of your Drive System?
Standard Wheels 12 46.15%
Omni Wheels 10 38.46%
Rubber Treads 7 26.92%
Additional Rubber Wheels 3 11.54%
Other 5 19.23%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
Unread 09-01-2008, 15:17
TJ4nier TJ4nier is offline
Professional Stress Monger
AKA: TJ
FRC #2168 (Fitch CyberFalcons)
Team Role: Leadership
TJ4nier is an unknown quantity at this point
Send a message via AIM to TJ4nier
Drive Configuration Poll
What are you using in your Drive System? Just a general concensus...
Professional Graciousism?
Gracious Professors?
Profess Graciousness?
No. Listen to the "W-Dawg" Flowers!
It's GRACIOUS PROFESSIONALISM.
Unread 09-01-2008, 23:17
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
Team Role: Mechanical
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: Drive Configuration Poll
we're going with powered wheels in front with powered omnis in the back, with the hope that we might 'fishtail' or 'drift' around corners....lets see if that happens the way we plan :-)
R16 Playing Configuration skimoose Rules/Strategy 11 07-01-2008 09:18
2007 Drive Train Poll FTtyler Technical Discussion 24 03-09-2007 17:43
Belt Configuration Hadi379 Technical Discussion 8 10-01-2007 02:57
Configuration File? FFnut Programming 2 03-02-2006 17:38
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
