Go to Post ...I've changed my position. I'm fully supportive of Joe's suggestion... - Chris Hibner [more]
Unread 09-01-2008, 16:34
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
G14 & a difference between start & end of match
<G14>
When the MATCH ends, each TRACKBALL is at least partially supported by the
OVERPASS and not in contact with any ROBOT of the same ALLIANCE will earn a 12 point
bonus.
Then we have in Section 6.2.2 on pages 5 & 6:
The OVERPASS structure extends across the minor axis of the TRACK. The OVERPASS is
constructed of 1-1/2 inch O.D. steel pipe and connecting hardware. The OVERPASS is supported
by three vertical supports – one at each end, and one in the center (the center support is also part
of the LANE DIVIDER). The vertical supports rise above the horizontal portion of the OVERPASS,
to a total height of eight feet and four inches. This is to help prevent TRACKBALLS from rolling off
the OVERPASS and exiting the arena, or rolling across the center of the LANE DIVIDER. The horizontal portion of the OVERPASS is 6-1/2 feet above the floor. The rails of the OVERPASS are
spaced 32 inches apart (center to center). On each side of the OVERPASS, a series of spacer
bars define three TARGET LOCATIONS on the OVERPASS. The TARGET LOCATIONS are sized
to allow the TRACKBALLS to rest within them.
And then of course, G20
<G20>
TRACKBALL Locations - After all ROBOTS participating in the MATCH are in their starting
positions and the TEAM members are in the ALLIANCE ZONE and/or ROBOCOACH
STATIONS, four TRACKBALLS will be placed on the OVERPASS. On each side of the
OVERPASS there are three TARGET LOCATIONS for TRACKBALLS. The field
management system will randomly choose an initial starting location for the TRACKBALLS
before the start of each MATCH. One red and one blue TRACKBALL will then be positioned
in the chosen TARGET LOCATIONS on each side of the OVERPASS. After this point in
time no ROBOT may be moved or repositioned until the MATCH starts.
At the start of the match the balls will be randomly placed on the Overpass but it doesn't say anything about them being placed solely in the Target locations.
In Section 6 on page 5 we can plainly see in the picture the possibility of 7 different places (on each alliances side) the balls can rest in. (3 large spots, and 4 smaller ones)
Will the Starting condition only have balls placed in the 3 TARGET LOCATIONS, or all 7 open spots??
Will a ball in either of the 7 spots be counted at the end of the match?
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 09-01-2008, 16:42
greenj12356 greenj12356 is offline
Rookie Year: 1999
greenj12356 is an unknown quantity at this point
Re: G14 & a difference between start & end of match
I think four of those spots don't count, they don't look like they are the same size and I would guess the balls would only be placed in the 3 target locations at the start and end of the match.
Unread 09-01-2008, 16:44
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I agree they'll be in one of the target locations for the start... but at the end they'll be where ever the robots put them, and it doesn't matter if its in a starting location or not, so long as it's supported by the overpass and not touching a robot on your alliance.
Unread 09-01-2008, 16:55
From what I read, I believe this one to be true. 3 static starting postions, and anywhere on the Overpass at the end.
I would like to see a clarification of my interpretation of this though just to be 100% certain.
Unread 09-01-2008, 17:16
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Elgin,
Have you tried posting in the Q&A thread?(http://www.chiefdelphi.com/forums/sh...ad.php?t=61080)
That should provide the clarification that you are looking for.
The way that I understood these rules was that the trackballs just have to be placed on the overpass at the end not specifically in one of the 3 starting positions.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 09-01-2008, 17:18
Originally Posted by SSMike View Post
Elgin,
Nope. Not yet. I just wanted to get some opinions of the rule before I (or someone else for that matter) posted it. I just wanted to be sure I wasn't missing anything blatantly obvious before asking FIRST.
Thanks for all the replies.
Next stop, Official FIRST Q&A Fora.
(With this and about a million other questions I'm sure as the year progresses.. )
Unread 09-01-2008, 20:26
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Yes, it does.
Originally Posted by <G20>
...The field management system will randomly choose an initial starting location for the TRACKBALLS before the start of each MATCH. One red and one blue TRACKBALL will then be positioned in the chosen TARGET LOCATIONS on each side of the OVERPASS....
G14 - ball on rack at end ericand Rules/Strategy 5 09-01-2008 08:00
The end of Doom & Quake? Raven_Writer Chit-Chat 6 13-09-2004 20:35
pic: The Bobcats 2001 &amp; 2003 &amp; Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
Difference Between Motors shyra1353 Motors 4 13-01-2004 10:12
Friction Between Bins & HDPE Gary Bonner Technical Discussion 2 14-01-2003 08:56
