Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
Unread 09-01-2008, 19:08
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
IFIloader and usb converter does not work
Ifiloader does not work with the usb to serial converter i am using.
It connects and when i click download it just sits on establishing port connection and then freezes up. Samething with the terminal when i open it and hit reset it freezes.
Unread 09-01-2008, 19:20
HighLife's Avatar
HighLife HighLife is offline
Mentor
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Re: IFIloader and usb converter does not work
From your last post you indicated you were using Ubuntu. Are you still trying to use the windows version in wine? That's probably not the right way to go. Or is this on windows now?
AdamBots.com- Winner of 7 Best Website Awards!
Unread 09-01-2008, 19:26
FRC #1087
could not get it working with linux, so i dual booted with Xp, and its still not working
Unread 09-01-2008, 19:41
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
If you are in linux try using Jifi (a java ifi loader clone)
http://shtylman.com/jifi/
Unread 09-01-2008, 19:43
FRC #1087
I get an error,
C:\Documents and Settings\Jason\Desktop\jifi\Jifi.exe
This application has failed to start because the application configuration is incorret. Reinstalling the application may fix this probelm
Unread 09-01-2008, 19:46
FRC #1087
i tried the older version, but when i click upload it says
RC not found.
Check that the RC is in program mode and connected to the right port.
Unread 09-01-2008, 19:58
FRC #1087
and the port and everything is setup right
im guessing it is the adapter, so i will go buy another, which one have you gotten working with linux?
Unread 09-01-2008, 20:25
sportman3333333 sportman3333333 is offline
FRC #0999 (CRASH)
Rookie Year: 2007
sportman3333333 has a spectacular aura aboutsportman3333333 has a spectacular aura about
Last year we had the same exact problem with the code. It coudnt upload and always gave us errors and saying incorrect port. We fixed it by getting a usb to serial converter. That pretty much solved the problem.
Unread 09-01-2008, 20:39
FRC #1087
I have a serial convert that does not work Did you get yoru converter working with linux? if so what model do you have?
Unread 09-01-2008, 20:54
FRC #0999 (CRASH)
Rookie Year: 2007
We used XP to get ours working. When I get a chance tommorow, I will get the model #.
Using a USB to 15 pin converter gillejr Control System 7 29-01-2007 20:44
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
USB-Serial Adapter and IFILoader under Linux Venkatesh Programming 3 03-12-2006 22:52
Arcade Mode (12) does NOT work jakk Programming 2 10-07-2006 19:27
Chaos theory does not work!!!!! S9ar7acu3 General Forum 3 09-02-2003 11:46
