Go to Post How do You Chiefdelphi? :cool: - SpaceOsc [more]
Unread 09-01-2008, 19:57
JspRaven JspRaven is offline
FRC #1865
JspRaven is an unknown quantity at this point
Hurdling the Ball in a Diagonal Way...
Hello,
We have a few questions, and they are the following:
1.) Is it okay to hurdle the ball diagnoally across the other side of the field?
2.) Does going through the finish line with the ball count as having possesion?
3.)Can you hurdle on your side only, or both?
4.) Define Home Stretch.
5.) Can we exceed the six feet height limit on opponets side?
Unread 09-01-2008, 20:03
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Hurdling the Ball in a Diagonal Way...
Originally Posted by JspRaven View Post
Hello,
OK, I'll answer these as best I know how.
1) I don't know, but if you can do it without going over the dimension, then I think so.
2) If you are contacting the ball, you don't get the points. If you go through with the ball, you may or may not be in possession. Try the definition of Possession in Section 7.
3) Both, but I don't know why you'd hurdle on your opponents side. You don't get any points there. See Section 7.
4)The quadrant immediately preceding and including the Finish Line, as you travel counter-clockwise. Begins at the land marker and ends at the Finish line. See Section 6.
5) Yes. See Update #1.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-01-2008, 10:04
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The only thing i'll add is to #1: If you hurdle such that the ball goes over the lane divider before passing over your finish line, you might have a problem as technically the ball never crossed your finish line (thus isn't a hurdle?). Might be worth getting some clarification from the FIRST Q&A.
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
hurdling daftpunk79 General Forum 5 08-01-2008 20:06
Hurdling akash155 Rules/Strategy 3 05-01-2008 23:50
2WD diagonal System Tom McCurdy Technical Discussion 11 23-01-2005 01:02
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
