Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 09-01-2008, 21:50
charmed862 charmed862 is offline
Robot Chick
AKA: Ashley
FRC #0862 (Lightning Robotics)
Team Role: Human Player
charmed862 will become famous soon enough
Send a message via AIM to charmed862
Question Questions on Mecanum Drive Train
Our Team Is Looking At Mecanum Wheels Any Comments comparing turning (not strafing) Compard to 4 wheel drive tank steering turning. Is it just as fast? Also, how about straight forward/reverse speed. Can Mecanum achieve 10-12 feet/ sec? I realizethat Mecanum are not as efficient.
Unread 09-01-2008, 22:12
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Questions on Mecanum Drive Train
I'm wondering really, what the maximum force of the four biggest motors is ( the most powerful can't give the name or seral number sry)?
Is now an engineer thanks to FIRST.
Unread 09-01-2008, 22:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
With the appropriate control of motor speed and direction, a mecanum drivebase will turn on a dime and give you nine cents change. No skips. No hops. No skids. Just smooth turning, as fast as you want. Sometimes faster, if you're not careful.
As for speed, it's all about gear ratios. You'll trade away torque if you want speed, just as with any scheme.
Unread 09-01-2008, 22:23
XXShadowXX's Avatar
They call me Cody.
naturally....
but i want to know is how fast can you get off at the start, accleration...
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
Mecanum Drive Technique Dan Petrovic Technical Discussion 9 16-08-2006 20:42
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train archiver 2000 1 24-06-2002 00:37
